Results 21 to 30 of 42
Thread: Engine light again...third time
  1. #21
    Quote Originally Posted by goldbergv95 View Post
    here are some people with the same problems as mine.
    http://www.hptuners.com/forum/showth...ighlight=p0757
    You disabled P0757 and it still lit up...?
    With the 0411 PCM (in the F/Y-cars) the code will stay disabled (what Vince at FLT said to do).
    You would do this if your TCC was unlocking due to misfires (there a TSTATE bit indicating this).
    Also, try doing a CASE relearn first (stall converter has less mass than stock, so misfire algorithm may misdetect misfire).
  2. #22
    Sep 2008
    well now im hearing a loud metal noise under the floor. im guessing trans, engine or tc. And no im afraid to drive it
    2002 4.2L I6 Trailblazer LTZ
  3. #23
    Sep 2008
    well it wasnt the trans or tc it was the ABS light that popped. I dont understand why since the hub are pretty new. Does anybody know how to turn off the ABs light?
  4. #24
    I think its time to take it to a dealer or independent shop and see what they say...trying to diagnose these problems is next to impossible via the web. I think there's something more going on that isnt related to the PCM flash at all, there is no reason the ABS stuff should even pop up unless there's an issue with the system itself. Ive never got any ABS codes after reflashing, and Ive flashed the same P10 in my 02 like 300-400+ times.
  5. #25
    Sep 2008
    well after 3 long months at the dealer we replaced the hubs and got a case relearn but i still get the engine light. What else is there to fix?
  6. #26
    Sep 2008
  7. #27
    Oct 2006
    Try setting P0758 to 'Not Reported" , worth a shot .
    Isn't a stock stall in the Trailblazer around 3200 ?
    2006 Trailblazer
  8. #28
    Sep 2008
    Normally a regular Tb has a 1600 stall, but a TBSS has a 1800 stall. Since i have and I6 engine with a Yank 3600 stall the stall decrease to about 3200.
    Thanks! Ill try to turn off the code and see what happens.
  9. #29
    Sep 2008
    well i turned off p0758 and it still occurs. My friend tells me when it reaches 40 mph the noise it makes sounds like the changing gears are changing too early. why does it make this noiss?
    Wait4Me Tune Original OS Part 7 4.11 TCC.tun
  10. #30
    Sep 2008
  1. Check engine light/No code?
    By Brad-06-Dmax in forum Duramax 06 LLY / 06+ LBZ & LMM
    Last Post: January 14th, 2010, 05:25 AM
  2. My engine light just pop out!
    By goldbergv95 in forum LL8 4.2L In-Line 6 - P10 PCM
    Last Post: January 31st, 2009, 03:02 PM
  3. check engine light after pcm swap ls1
    By Adam Calley in forum General (Petrol, Gas, Ethanol)
    Last Post: February 3rd, 2008, 07:54 AM
  4. check engine light ?
    By Boost in forum General (Petrol, Gas, Ethanol)
    Last Post: March 14th, 2007, 02:22 AM
  5. Change Engine Oil Light?
    By 87gmc in forum General (Petrol, Gas, Ethanol)
    Last Post: August 30th, 2005, 07:53 AM
