Results 1 to 10 of 15
Thread: 411 computer semi-opened loop
    May 2008
    Default 411 computer semi-opened loop
    I just replaced the computer in my 97 Yukon with a 411, I updated the OS to 02020003.
    I've tried everything to get it to work semi-open loop:
    1) B3647 set for 14.63 at idle and cruising
    2) B4205 all set to 255
    3) B3801 set to disable
    4) B3601 all set to 14.63
    I did this with my 71 firebird, different computer and OS 01270003 and it works great.
    What am I doing wrong?
    Lee
    230" Dragster - 2000 LS1, 02020003 Speed Density, PRC 2.5 Heads,
    MS3 Cam 237/242 .603/.609, Vic Jr. intake, Holley 1000CFM TB,
    PowerGlide, 5000 stall converter. 8.70@154 MPH
    My Projects Homepage: http://www.horsepowerracing.com
    May 2008
    Anyone? Even if your just guessing I would appreciate some help!!
    Lee
    May 2008
    Somebody at EFILive tech support should have an answere to this problem....They wrote the program so there has to be a brainiac there, someone go wake him/her up!!!!
    Lee
    Nov 2006
    What is the problem?
    Fuel trims are off (0%) and you are commanding 14.63 AFR in OL.
    Is this not "semi-open loop"?
    If everything is "working" with another tune you have, create a script from it and use it against this tune to see if there is something you missed.
    IMO
    The real question should be why are you logging LTFT, STFT and O2 voltage when you don't want them to control fueling and why so many PIDs?
    The channels count is sky high.
    LC-1 WBO2
    May 2008
    Fuel trims are 0 because the computer isnt going into semi-open loop and modifying the fuel.
    I have no idea how to use scripts. And it's a different OS.
    I logged LTFT to see if they are being used, as in going into closed loop. It was just another place I was looking for answers.
    I'm logging STFT and O2's because that's were you see the computer trying to maintain a 14.63 AFR, hence semi-open loop. Have you used semi-open loop?
    See below the other cars log and tun file. You can see at frame 1283 the computer goes into closed loop mode and the O2's start dancing like they're supposed to.
    Is your VE table correct (BEN equals 1.00)...?
    May 2008
    They are getting closer but I'm not finished yet.
    Here's a more current log of driving, I'm working out the shifting issues before I tackle the AutoVE. Right now it shifts really hard on the 1-2 and soft on the 2-3. It has a shift kit and I'm just about ready to remove it and go completely back to stock! I had a supercharger and an Ed Wright tune on it and it always shifted too early with his tune. I can tell you this though, it has NEVER ran this strong before, the throttle is so crisp now. I kinda wish I left the supercharger on and did this tuning, but the dragsters getting the supercharger!
    Nov 2006
    Semi-OL = Use O2 With Open Loop? (STFT)
    I'm not hip to the semi-OL thing,
    I assumed with commanded AFR table @ 14.63 that is SOL.
    Does this OS have {B4206}?
    STFTs are still 0%, does that = no SOL?
    LC-1 WBO2
    May 2008
    Correct, it will use the O2's to maintain 14.63AFR, nice for idle and cruising.
    Yes it has B4206 and all values are all 255 per the manual.
    Correct, 0's mean no SOL. If you look at the firebird log you will see it in action at frame 1283.
    May 2008
    Could there be a problem with 0202003? 01270003 works great.
    EFILive techs with 0202003, can you setup a car in semi-open loop just to see if it works on yours?
    Lee
  1. clarification on semi closed loop SD
    By Cablebandit in forum Custom Operating Systems
    Last Post: October 5th, 2009, 01:51 PM
  2. cos3 semi closed loop
    By kostelacd69 in forum Custom Operating Systems
    Last Post: September 11th, 2009, 08:49 AM
  3. Setting up for semi open loop
    By jfclubby in forum Custom Operating Systems
    Last Post: September 19th, 2008, 02:56 AM
  4. COS5 semi open loop ?
    By RandyWS6 in forum Gen III V8 Specific
    Last Post: April 10th, 2008, 03:38 PM
  5. semi closed loop
    Last Post: August 12th, 2007, 01:58 AM
