Page 1 of 3 123 LastLast
Results 1 to 10 of 27
Thread: acetone improve fuel economy?
    Lifetime Member smslyguy's Avatar
    Oct 2008
    Default acetone improve fuel economy?
    has anyone ever tried to use acetone in the fuel tanks and has anyone had any sucess?
    Last edited by joecar; October 20th, 2010 at 09:27 AM. Reason: Fixed spelling in title (allows searches to find this thread)
    2001 camaro z28 ss vert with factory slp upgrades, Hooker long tubes, 3"y-pipe to a 4" muffler, ,airlid,s.s.r.a. ,t.c.bypass,descreened m.a.f. 232/234 .595,.598 +2 comp cam with ported and polished stock heads with .650 lift dual springs and a bowl grind. tuned with EFI Live. All combined to achieve 29 m.p.g. and 399 r.w.h.p. with 384 lbs of torque. sold...
    Now own a 2015 1LE camaro
    Nov 2006
    No but I knew this tweaker dude back in the day,
    that used paint thinner to run a generator.
    I ran for a little while.
    LC-1 WBO2
    Oct 2008
    http://www.pureenergysystems.com/new...00069_Acetone/ check this site out, supposedly it is supposed to have huge gains in m.p.g
    Nov 2006
    "Not more than three oz. per 10 gallons."
    It's kind of an old article, there surely is some follow up somewhere.
    LC-1 WBO2
    Oct 2008
    must be. My main concern was the effects it would have to your engine? Supposedly its not good with plastic.
    Jul 2005
    Default We need to believe
    At this concentration the only probable benefit is the cleaning effect that the acetone would have on the fuel injectors. As far as the possible problems that the acetone could could cause, keep in mind that acetone is sold in plastic at Bunnings.
    It would probably work well on an old gummed up set of injectors, just like the ones that the people on the 'hypermilers' forums seem to test the acetone on.
    My preference is for the marine 2 stroke additive that is doing the rounds.
    Just my 2 cents worth.
    Cheers, Steve
    Just got off the showroom floor, now lets fix it.
    Aug 2009
    I've tried it with limited success. I have friends that claim great MPG increases. The best I've seen that I could confirm from it was 10%. I thought it might help me to run mid- grade or regular in my vehicle that requires premium, but it didn't. It also doesn't seem to help with any fuel that has alcohol added to it.
    Lifetime Member tokymon's Avatar
    Apr 2008
    ya i have tried this in many vechiles works good a inj. cleaner
    97 2500 ecsb 5.7l/4l80e/4x4 411 pcm /thorley tri-y's/dual super 40's with x (catless)/aem cai/msd 6a and coil/zz4 cam/beehive spring/lm-1
    stock sucks
    Oct 2008
    have you ever heard of it damaging your injector seals? or any other seals for that matter?
    Nov 2006
    Quote Originally Posted by tokymon View Post
    Why not just use an injector cleaner?
    LC-1 WBO2
  1. Fuel Rail Pressure's relationship to fuel economy.
    By duramaximizer in forum Duramax 06 LLY / 06+ LBZ & LMM
    Last Post: February 28th, 2010, 01:18 PM
  2. E38 Crank Fuel to Run Fuel Transition
    By Wazzup13 in forum E37, E38 & E67 PFI ECM's
    Last Post: August 1st, 2009, 11:12 AM
  3. Converting a NON-Flex fuel vehicle to Flex fuel??
    By kbracing96 in forum General (Petrol, Gas, Ethanol)
    Last Post: August 1st, 2008, 06:15 AM
  4. LOW FUEL PRESSURE logging for low fuel pressure nirtous systems
    By WiseGuyZ06 in forum External A/D inputs
    Last Post: October 11th, 2007, 12:56 PM
  5. part throttle fuel tbls and WOT fuel tbls
    By ZL1Killa in forum General (Petrol, Gas, Ethanol)
    Last Post: January 7th, 2006, 06:49 PM
