Results 1 to 10 of 30
Thread: Cold AFR doesn't follow commanded AFR
    Jan 2007
    Quote Originally Posted by LS1_Dragster View Post
    No, the engine is a 98 454 L-29 and 4L80E trans, I just changed everything to make it work. I wish I could edit those fields so I could put in what the engine/year etc really is. In fact if I change the VIN to the firebird's I loose the PID's.
    You can....I think.
    My VIN used to show as being an Express or Savanna depending on what base tune I used....either that or 'unknown' if I used my correct Vin.
    You can go into the Program files, EFILive, V7.5, Configuration and alter the 'Vin' file to read what you want in your 'VIN' tab in the tune.
    I put my 'correct' numbers in and just added lines to make it read Chevy truck - Australia.
    Howard
    DUCT TAPE.
    98 K1500 'HOLDEN' Suburban.
    May 2008
    Quote Originally Posted by hquick View Post
    You can....I think.
    When I changed the VIN to the actual firebirds VIN then when I loaded it next it said it couldnt valid the PIDs or something like that so I put the original VIN back in. I think if you put in a valid VIN it would work. I suppose I could mess with it some more...
    Thanks joecar.....
    230" Dragster - 2000 LS1, 02020003 Speed Density, PRC 2.5 Heads,
    MS3 Cam 237/242 .603/.609, Vic Jr. intake, Holley 1000CFM TB,
    PowerGlide, 5000 stall converter. 8.70@154 MPH
    My Projects Homepage: http://www.horsepowerracing.com
    Lifetime Member Aloicious's Avatar
    Nov 2007
    Thanks joecar.....
    the firebird's VIN is probably a different format than the PCM is able to recognize due to its age. my 12200411 PCM recognizes my '96 truck VIN just fine. and I'm able to use all the LSx PID's without an issue.
    1996 c1500 gen1e 5.7L - the "LS31", 24x CNP, LS2 coils, modified T56, 12200411PCM running COS3, zz4 cam, custom MPFI, etc. coming soon: Twin Turbos
  1. My AutoVE doesn't look right??
    By Mr. P. in forum Gen III V8 Specific
    Last Post: December 2nd, 2009, 07:01 AM
  2. LOG doesn't get written IF car shuts down first
    By Highlander in forum FlashScan V2 BB Logging
    Last Post: May 6th, 2009, 05:00 AM
  3. LC-1 doesn't work pass though
    By samh_08 in forum FlashScan V2
    Last Post: April 19th, 2009, 08:53 AM
  4. searching doesn't like me much... 2.73's to 3.42's
    By Koncrete in forum General (Petrol, Gas, Ethanol)
    Last Post: January 22nd, 2007, 06:56 AM
  5. Why doesn't SAE.MAP not work? (2-bar)
    By Alvin in forum Custom Operating Systems
    Last Post: October 27th, 2006, 06:07 PM
