Page 2 of 5 FirstFirst 1234 ... LastLast
Results 11 to 20 of 41
Thread: Imperial pids for BBL?
    Apr 2008
    Well thought I give it a try and remove what I had to install the newest release off the site instead of the updating I did to get to build 58 from build 55. It did delete EFILive.ini during the uninstall. But on reinstall it still does allow a change of Imperial or Metric values for the PID.
    Can I get a copy of the build 55 release or link to it and install that to see if it restores itself.
    One funny thing is after I installed V8 build 58 it said there was and update. Well the install says build 58 and of course the update still ends up as build 58. No idea there. But still not changes to metric or imperial.
    Got a few more things to check but looks like a bug that may not be calling the right Header in EFILive.ini file.
    If anyone is still V8 build 55 or earlier please post your EFILIve.ini file for comparison.
    Brian
    Lifetime Member LBZoom's Avatar
    Jun 2008
    Thanks Mr.Prick for posting that for me. I'm still lost about changing over to imperial with V8, my software doesn't have the option when I right click after dragging the PID over, any thoughts? Is it something in my options.txt file, what needs to be done there?
    Peace Through Torque
    www.PunisherPerformance.com
    Just tested the latest update here and got the same problem. Will fix it asap - apologies for the bug.
    Apr 2008
    No problem there Paul. Can't always be perfect. But just curious if one can access older EFILive software?
    Brian
    Quote Originally Posted by Brian1 View Post
    Brian
    No we don't keep old versions on our server.
    Meanwhile, you can simply enter the conversion factors for Imperial units in the PID Property window. The drop down list box is really only for convenience. Use the EFILive.ini file as a reference to see which factor/offsdet values you need to use for various conversions.
    Has this been fixed? If so I missed the fix.
    Sep 2003
    Quote Originally Posted by minytrker View Post
    It doesn't look like it as the last update was prior to Paul's post. It probably got lost with BBL reading beta testing. Paul hinted that BBL reading was going well and an update should be available soon (day/week/month ?), hopefully all the fixes will be in it.
    Yes, the fix for Custom PID units is in the BBR update.
  9. #19
    What update is it? I thought I was up to date.
  10. #20
    Sep 2003
    You probably are up to date, but per Paul from another post.
    The BBL has had a major "refit" and the update will be available as soon as the BBR (Black Box Reading) option has made it through the beta test phase.
  1. Question displaying Imperial during BBL
    By Brian1 in forum FlashScan V2 BB Logging
    Last Post: November 8th, 2009, 02:15 PM
  2. Imperial vs Metric
    By killerbee in forum General (Diesel)
    Last Post: September 3rd, 2009, 09:16 AM
  3. Changing Pids to Imperial??????
    By turboolds in forum FlashScan V2 BB Logging
    Last Post: June 17th, 2009, 10:17 AM
  4. Imperial MAP values seem backwards
    By kp in forum General
    Last Post: March 9th, 2005, 06:40 PM
  5. Imperial MAF units in the V7 scan tool
    By XLR8NSS in forum General
    Last Post: February 26th, 2005, 11:38 PM
