Page 10 of 26 FirstFirst ... 8910111220 ... LastLast
Results 91 to 100 of 258
Thread: using 14.047 for desired AFR and not 14.63?
  1. #91
    Lifetime Member 98 tigershark's Avatar
    Nov 2006
    Default I am kind of familiar with that thesis.
    I have read a few articles on that as well but wasn't it determined to be not reliable with most all of the non flex fuel PCMs.
    If I recall correctly, the Ethanol fuels can trick the O2 sensors and therefore the Long and short term fuel trims.
    That was the conclusion right?
    98 tigershark
    Didn't someone else explain how the newer OSs use STFT to detect Ethanol and make changes in the tune rather than using the sensor , think it was in the same thread .
    98 tigershark
    L92/427 w/L76 CC'ed heads n upgraded springs
    4.100 stroke, 4.068 bore w/ 11:1 comp
    Cam, 591 int, 613exhst, [email protected], 115*
    LG headers, High flow cats,
    RPM level 5 trans, RPM 3.42 gears, 2800 rpm trq convrt. .
    Special Thanx to Joe and Bruce!
  2. #92
    Nov 2006
    So STFTs change EQ1 in a GEN3 OS?
    I don't recall reading how STFTs would detect what the Ethanol% is
    therefore changing EQ1 automatically.
    Newer OS' have a more defined stoich table per Ethanol%
    The OP has a C5,
    {B3601} is static with no way to change EQ1 for varying Ethanol%.
    Example:
    If EQ1 is set for gas (14.6AFR) and you have E10 (14.1AFR) in the tank
    you are still going to command 14.6AFR not 14.1AFR and
    all other fuel tables are stuck at the EQ settings based off {B3601} (14.6AFR)
    Quote Originally Posted by eficalibrator View Post
    Ideally, you just set your defined stoich point in the table to whatever the chemistry of your fuel really is and leave it alone. (I use 14.13 for e10, 14.64 for "normal" gasoline, and 14.4 to split the difference if we're unsure of what's in the tank)
    This answered the original question.
    If you want to run more than one fuel type/mixture things complicated
    with a stock C5 OS,
    it's either one fuel type or the other.
    LC-1 WBO2
  3. #93
    Dec 2007
    Default GM's Virtual Fuel Sensing for Flex Fuel
    Team,
    It looks like GM's Virtual Fuel Sensing "technology" is being alluded to.
    A few years ago GM announced that it had developed "Virtual" Fuel Sensing for Flex Fuel vehicles as an innovation that avoided the requirement for a "real" flex fuel sensor. The $700 list, $400 street sensor that sends fuel composition info to the PCM/ECM.
    Read about the tech details on the "real" sensor here. It also details the FF GM vehicles the "real" sensor" is used on.
    http://www.megamanual.com/flexfuel.htm
    In short it provides a 50 - 150Hz square wave to the PCM/ECM to indicate ethanol content, and is smart enough to detect fuel contamination, and indicates fuel temperature via modulating the pulse width of the square wave.
    The operation of GM's Virtual Sensor (VFS) is described in the GM patent
    attached in "patent speak". Enjoy the read .
    GM-VFS US Patent 7159623.pdf
    In short "it" uses fuel tank level changes to decide the tank has been filled and runs a cycle using the O2 sensors & trims to help decide what the E content is and then references various other E tables in the PCM/ECM to get the timing and the fueling optmised for E.
    Interesting stuff.
  4. #94
    Feb 2008
    Quote Originally Posted by gmh308 View Post
    Team,
    Interesting stuff.
    I am under the impression that the fuel level sensor need to be connected on conversions also to switch back to the High octane table. If you have a conversion with out a fuel level sensor you will be stuck on the low octane table.
    funny how GM uses that sensor for more than just the EVAP system.
    Cal Editor aka A.J.
    Lead Calibrator at PCM Calibrators
    ASE Master Certified since 1988 -- ASE L1, F1 & A9
    GM Technician since 1999 -- GM World Class Technician since 2009
    CNG Installer -- CSA Inspector
    A handful of people out there who do have an intimate knowledge of GM Calibrations
  5. #95
    Dec 2007
    Quote Originally Posted by CalEditor View Post
    If you log the Octane scaler, and it is above zero, you will see it ramp back down over time towards zero. Sometimes this occurs quickly, sometimes not. Seems to depend on frequency and severity of knock. Which makes good sense.
  6. #96
    Nov 2006
    Default Hey Thanks gmh308
    That is pretty cool stuff. Thank you so much. I had seen some thing like this awhile back last year. Didn't they have a separate fuel tank specification that was patented separately but must be used with this system? I think is was a sort of chopped top of pyramid style tank. I am going off of memory here so take that for what it is. Do you know anything about the special tank for this, I heard only heard of this but I think it is true. What say you gmh308? gm General manager? So what do we do?
    Thanks again as that is really cool. I am curious as to how you found that,
    Very grateful,
    98 tigershark
    98 tigershark
  7. #97
    Oct 2006
    Quote Originally Posted by 98 tigershark View Post
    OK Chevy366,
    I give up, I cant find the place that addresses the Earlier PCMs (non flex fuel) and Ethanol fuels. Can you please post the link, Pretty please. Before you visit your still would be nice. I had a tractor too (A Kiote), but my cows are now eaten. Pigs are much easier.
    98 tigerhsark
    Sorry , I think I used 'Ethanol sensor' in search criteria . Try that , if not I will see if I can find it again .
    Oh , watch the country hick comments , not funny !
    2006 Trailblazer
  8. #98
    Nov 2006
    Default Sorry but I am a redneck!!
    Hey Sorry Chevy366,
    I do have a tractor, I did raise cows and I do occasionally raise pigs and I have a small farm.
    Even though I have never hunted from my deck I could!!
    I do live in the sticks and I like Jeff Foxworthy, I think I got his name right.
    We are a little sensitive today so sorry! Because I live in the sticks it is hard to get good gas and diesel.
    Thanks,
    98 tigershark
    Last edited by 98 tigershark; September 7th, 2009 at 07:45 AM. Reason: Attachement
    98 tigershark
  9. #99
    Nov 2006
    See My tractor in the background!
    98 tigershark
  10. #100
    Feb 2008
    I will trade you my place in city next to Harley Davidson's R&D head quarters for your place in the NW any time. Then I would be set. My little shack in Rock Hill SC and a place in the Good Old NW. I could actually go visit friend and relatives for a change.
    Cal Editor aka A.J.
  1. B0720-FRP: actual or desired?
    Last Post: November 11th, 2009, 05:55 AM
  2. Desired Airflow Map, not quite right, help
    By kwhiteside in forum Gen III V8 Specific
    Last Post: September 8th, 2009, 07:14 AM
  3. Desired Shift Time
    By A6sportsracer in forum 6 speed/8 speed RWD/FWD Transmission Tuning (incl T43, T76, T87)
    Last Post: June 27th, 2009, 11:45 AM
  4. How does desired boost work?
    By pistonrings in forum Duramax LLY
    Last Post: May 30th, 2009, 04:47 AM
  5. Desired Airflow
    By Thumper in forum Gen III V8 Specific
    Last Post: April 23rd, 2008, 02:23 AM
