Some of us are trying to figure out what crank/cam/valve event the injector timing tables are relative to (e.g. time BBDC...?)...
We appreciate your efforts in experimenting with this...
5.7ute (Mick) is very interested in this.
Hi Joe
I believe the injector timing is in crank regress and relative to TDC on the compression stroke?
Foe example on the LS2 the advance is 490 degrees when cold and 220 degrees at normal running temps, so the timing events for the LS2 are as follows:
Engine cold
Inj fires. 130 BTDC. CLOSED INLET VALVE
IVO. 16 ATDC
ICL. 118 ATDC
IVC. 40 ABDC
Engine hot
IVO. 16 ATDC
ICL. 118 ATDC
Inj fires. 140 ATDC. INLET VALVE BEGGINING TO CLOSE
IVC. 40 ABDC
