Quote Originally Posted by Goldfinger911 View Post
The reason I bring this up is I was amazed to see how a slight movement of the injector firing event affects idle, AFR, idle load, and throttle response. You also immediately notice things like, your AFR getting leaner on the gauge, but the exhaust smelling like unburnt fuel. So far, adjusting the event so as to yield the richest idle mixture (the most burnt fuel at a fixed pulse width) seems to get me closest to optimal with everything else.
I was considering the the exhaust valve timing when cold, if the valve is open later, then perhaps the timing should be retarded in line with the difference from the stock cam. For example the stock cam closes 6 BTDC, my cam closes 1.5 ATDC, so I might need to retard 7 or 8 degreeswhen cold??
