this is on a 06 LLY.
efi has detected that this ecm may not have a valid calibration
ecm does not contain a valid calibration
bootloader rejected
reason: efilive could not unlock the ecm
using alt keys i get bootloader rejected response code $11
bootloader rejected
Jason, is this from the blx files you sent me today?
If so, it looks like you are trying to use the V1 hardware on that truck, if so it's not possible as the V1 has no CAN bus support (which the 06 LLY is).
ross, ya i brain farted this was my first 2006. thank you for your time.
jason
