Page 2 of 2 FirstFirst 12
Results 11 to 17 of 17
Thread: Solid Motor mounts setting off KR
    Jan 2008
    good deal, I will see if I played around with those tables yet.
    I definately did some manipulation on some tables based on a search finding, but I will try your values. I would try a cyanide capsul at this point.
    97 MN6 vette, Vortek, BBK 80 FAST 78 manifold, 42# racetronix, lingenfelter edlebrock heads 202cc, 228 232 .622 .630 111+2, patriot dual ex, yt roller rockers, lg pro, now with cats, .041 Mr. Gasket (cometic leaked), 62cc head, ~60 cc chambers, custom built coilovers, ADDCO sway bars
    Jan 2008
    I went from the Ray tune to the Ray w 97knockmod and the log is the result of the knock mod.
    Jan 2008
    these were the previous tune and log to the Knock mod in the previous post
    Jan 2008
    I'm about to put cats on, can I put the wide band 02 after the cats?
    thanks
    Jan 2008
    I have a question about the AUTO VE PDF tutorial.
    Once you get the VE table adjusted through several iterations, the instructions take you through steps to revert some of the settings to open loop (I guess) but never instructs you to hook the MAF back up. Does it forget to tell you to do this or is it eliminating the MAF?
    To use the MAF again, don't I have to recalibrate it? Should I use the maf again?
    Shoud this come before or after the Knock is figured out?
    Jan 2008
    You may find that KR gets lower as cell count increases, so make sure you hit those cells more than once or twice before subtracting KR from the spark table(s)
    Try reducing {B6203} 30%, increase {B6702} 50% & increase {B6245} 5%.
    I do not have table B6702 on my 97 computer, the other's I found and adjusted but won't be able to try the tune till I get my exhaust back together.
    Any advice on the the wideband O2 placement is welcome.
    Junior Member LM7Tuner's Avatar
    Sep 2009
    The wideband should be before the catalytic converter for an accurate reading.
  1. knock retard because of motor mounts?
    By rat_rod_russell in forum General (Petrol, Gas, Ethanol)
    Last Post: July 27th, 2008, 01:23 PM
  2. c5 motor mounts
    By Adam Calley in forum General (Petrol, Gas, Ethanol)
    Last Post: February 26th, 2008, 04:36 PM
  3. gen 1 motor with gen 3 ecu
    Last Post: January 14th, 2006, 01:27 AM
  4. 402 ci motor
    Last Post: November 25th, 2005, 09:38 AM
