Page 1 of 3 123 LastLast
Results 1 to 10 of 23
Thread: What kind of changes are needed to run speed density
    Sep 2009
    Default What kind of changes are needed to run speed density
    I have a 04 gto with afr heads fast 92mm intake comp cams 238/242 605/609 111 lsa 6 speed with 3.91. I am thinking about going mafless. What changes do I need to make on my tune to do so.
    Lifetime Member limited cv8r's Avatar
    May 2005
    I'm pretty sure the "auto VE" tutorial explains the steps to run mafless, plus other things.
    It's all good until it goes "Bang"
    Jun 2005
    SD changes required:
    Flip MAF Fail frequencies: C2901 & C2904 (low becomes high and high becomes low)
    Change Fail Limits to 1: C2903 & C2906
    Copy High Octane Spark to Low Octane table
    Change MIL Enablers C6002: P0101, P0102, P0103 = No MIL
    (Don't change Processing Enablers)
    That will put you in SD.
    If you were going to tune with a WBO2, you would also want to go open loop.
    Open loop tuning changes required:
    Disable LTFTs - B3801
    Disable STFTs - B4205 (set all to 283*F)
    Adjust Commanded Fuel in Open Loop table - B3605 (set all rows 158*F and greater to stoich)
    Adjust PE Based on RPM table - B3618 (set as desired for WOT)
    Adjust PE Mode Enable - B3616 (adjust as desired by TP% & RPM when you want PE to activate)
    Disable DFCO - B3313 & B3308 (set to 283*F)
    Disable Cat. Overtemp Protection: B0701
    Sep 2009
    Thanks for the help.
    Oct 2009
    is it really that easy?
    -sorry for diggin up old crap
    Oct 2006
    Pretty much. If you arent using a COS you need to paste your high octane spark table to the low octane table since a fail mode kills the HO table.
    Also if you are running an auto you need to prevent excessive line pressure etc, which again is caused from the pcm seeing a maf failure. These are in tables E0102,E0103 & E0104.
    The Tremor at AIR
    Senior Member Sid447's Avatar
    Jul 2005
    Smile
    Quote Originally Posted by 5.7ute View Post
    ..........Also if you are running an auto you need to prevent excessive line pressure etc, which again is caused from the pcm seeing a maf failure. These are in tables E0102,E0103 & E0104.
    Learn something everyday!
    I didn't know about these (I'm M6) are these changed to Yes? Maybe there's a thread explaining this a bit more?
    Sid, those only apply to A4.
    Jul 2005
    Smile
    Hello Joecar
    Yes understand! But I'd like to broaden my horizon. Is there somewhere I can read up on this a bit more?
    Default Disable MAF DTC's in tables E0102, E0103, E0104
    This is all we have so far: showthread.php?t=10773
    Edit: link is now fixed... sorry about that...
  1. Speed Density
    By Yortt in forum Gen IV V8 Specific
    Last Post: December 1st, 2008, 01:11 PM
  2. Speed density run.
    By nissmo in forum Custom Operating Systems
    Last Post: October 30th, 2008, 03:05 PM
  3. speed density
    By mikesp1 in forum E37, E38 & E67 PFI ECM's
    Last Post: July 31st, 2007, 05:29 PM
  4. speed density
    Last Post: January 14th, 2006, 06:13 PM
  5. Speed density
    By Drake in forum Tutorials
    Last Post: February 22nd, 2005, 03:01 PM
