Results 1 to 3 of 3
Thread: AutoVE filter
    Feb 2007
    Default AutoVE filter
    I recently discovered a great additional filter for logs when doing AutoVE.
    Log Fuel Trim Cell Number, if you exlude values 16 and above which are for idle, deceleration, dfco and other ??? conditions, leaving just on the gas values.
    BEN values become very stable, I also filter engine temp <85 and >95, LC-1 sensor state values not = 1 and ETCTP CHANGING > 5%.
    Sensor status values
    0 "Unknown" "Unknown - possibly not connected"
    1 "Lambda" "Valid Lambda and AFR data"
    2 "%O2" "Free air detected"
    3 "Cal" "Calibration in progress"
    4 "NoCal" "Calibration required"
    5 "Warmup" "Warming up"
    6 "HCal" "Heater Calibration"
    7 "Error" "Error"
    Last edited by Gelf VXR; October 5th, 2009 at 12:42 AM. Reason: Added sensor status values
    Nov 2006
    EXT.WO2ST1 is a good PID to filter for RTACS so is RPM less than 400.
    Filtering out a narrow range of ETC is also helpful, 5°F+/- of average is my target.
    I personally wouldn't waste a precious channel on FTC but to each their own.
    LC-1 WBO2
    Some of us h ave found that DFCO doesn't show up in FTC21 or in STATE05.
  1. Fuel Filter
    By Shaftner87 in forum Duramax LLY
    Last Post: May 9th, 2010, 02:01 AM
  2. 9 sec. C5 Blower Car - No Air Filter - Help?
    By JR-CRUZN-C5 in forum Tips and tricks
    Last Post: September 30th, 2008, 09:04 AM
  3. Filter Sets
    By mr.prick in forum RoadRunner Real-Time PCM Emulator
    Last Post: August 17th, 2008, 07:17 AM
  4. wideband filter?
    By pwilson22000 in forum General
    Last Post: July 13th, 2006, 05:10 AM
  5. Filter Question??
    Last Post: July 27th, 2005, 10:13 AM
