Thread: 3 bar map sensor HELP QUICK
    May 2006
    Default 3 bar map sensor HELP QUICK
    I need a 3 bar map sensor for my 02 T/A. Anyone know a gm part number that will fit the ls1???
    02' T/A convertable,ram air,Procharger-D1SC,dual intercooled,Patriot stage 2 heads,small comp cam,childs & albert rods,forged pistons,fast ls6 intake,90mm throttle body,NOS,TH400,2500stall,trans brake,moser rear w/4.10's,tubeler upper & lower A-arms,QA1 raceing shocks,tubeler drive shaft loops,subframe connecters,OK to much to list.There is more!! Dynoed @ 520hp & 580tq. at the tires without nitrous.6.9@93mph 1.7 60ft. in 1/8.
    Aug 2008
    I found this on LS1 tech:
    3-bar MAP sensor(AC-Delco#213-1562)=12223861(formerly 16040749, AC-Delco #213-101)
    pigtail harness for MAP sensor (AC-Delco #PT1035) = 15305891
    FLASHSCAN V2 & AUTOCAL
    May 2006
    Where can i get these?
    GM dealer or GM dealer parts store online or AC Delco online.
    Nov 2009
    Which of these part numbers are good for a plug n play, or close, 3 bar map sensor?
    Lifetime Member johnv's Avatar
    Jan 2005
    I believe speedinc has them with plug and play harness, but they won't fit in the factory location so you will need to run a vac/boost line to it.
    Back yard boost
    347+ T76 = 770 rwhp 10.96 @ 135 mph
  1. Quick Question
    By duramax07tmd in forum General (Diesel)
    Last Post: March 16th, 2010, 03:06 PM
  2. quick o2 sensor question
    By justin123 in forum Gen III V8 Specific
    Last Post: February 1st, 2010, 09:54 AM
  3. quick ???
    By YANKGTO in forum General (Petrol, Gas, Ethanol)
    Last Post: November 4th, 2006, 07:21 PM
  4. Quick IFR ?
    By ViolatorTA in forum General (Petrol, Gas, Ethanol)
    Last Post: July 18th, 2006, 01:11 PM
  5. Quick ?s
    By jayshaw638 in forum Duramax LLY
    Last Post: February 26th, 2006, 12:46 PM
