Results 1 to 9 of 9
Thread: Tuning NB 02 lean for smog test (mot uk)
    Feb 2007
    Default Tuning NB 02 lean for smog test (mot uk)
    I'm sure I've read this being done on here but cannot find the post?
    If I wanted to program the psuedu NB output of an LC-1 to switch slightly leaner than stoich.
    At my last test I had tailpipe lambda 1.006 (limits 0.97-1.03)
    From the programmer text
    1.1V = 0.958 lambda (richer than stoich)
    0.103 = 1.022 lambda (leaner than stoich)
    0.97V = 0.064 difference between upper and lower limit
    0.064V = 0.01 lambda
    If I program the LC-1 as below would this work?
    1.036V = 0.958
    0.039V = 1.022
    Nov 2006
    Why not just change the commanded AFR.
    LC-1 WBO2
    Feb 2007
    It will be in closed loop for the emmisions test
    Nov 2006
    I mean change {B3601} Ratio of Air to Fuel for Stoichiometry.
    Your OS may have a different parameter number.
    This will change the CL and PE commanded AFRs.
    LC-1 WBO2
    Feb 2007
    My os does not have any calibrations of that type
    thanks thou
    Dec 2007
    Quote Originally Posted by Gelf VXR View Post
    thanks thou
    Which OS do you have?
    Can you program the NBO2 switch points in the PCM calibration...?
    If you do get it leaner, watch out that NOx levels increase (as you go leaner)... are the smog authorities measuring NOx levels...?
    Feb 2007
    The only table for idle airflow is {B1829} minimum desired airflow per gear.
    My OS is 02596734
    Feb 2007
    I don't think so, the results of my previous emmisions test, it does not list NOx
    Natural idle
    engine speed 450 to1500 rpm manual check pass
    CO =< 0.30% 0.3% pass
    Fast idle test
    engine speed 2500 to 3000 rpm manual check pass
    CO =< 0.2% 0.12% pass
    HC =< 200 ppm 14 ppm pass
    Lambda .97 to 0.93 1.006 pass
    I have aded the attachment image that shows the effects of AFR on the various emmisions
    Last edited by Gelf VXR; October 11th, 2009 at 10:05 PM. Reason: added emmisions image
  1. Passed CA SMOG!
    By LastCall in forum Gen III V8 Specific
    Last Post: May 27th, 2010, 06:48 AM
  2. Smog Inspection
    By Rich in forum General (Petrol, Gas, Ethanol)
    Last Post: March 25th, 2008, 07:01 AM
  3. PE tuning..lean on the bottom..
    Last Post: April 22nd, 2006, 02:37 PM
  4. Too lean to AutoVE test/tune !!??!?! Why?
    By Learning in forum General (Petrol, Gas, Ethanol)
    Last Post: April 19th, 2006, 02:32 AM
