Results 1 to 7 of 7
Thread: We can't filter State PIDs?
    Nov 2006
    Default We can't filter State PIDs?
    I just found this out today, GM.STATE0x is not in the filter drop down box.
    LC-1 WBO2
    Nov 2006
    I made a cal_pid for this.
    LC-1 WBO2
    That's what I do... (also, this way they can appear on a chart).
    Nov 2006
    It's not easy to do, I had to search for a while before I found out how.
    LC-1 WBO2
    Sep 2003
    What's the secret?
    Nov 2006
    The state PIDs have 8 "Bit Positions" and each have "RAW" value
    Bit position 7 = 128
    Bit position 6 = 64
    Bit position 5 = 32
    Bit position 4 = 16
    Bit position 3 = 8
    Bit position 2 = 4
    Bit position 1 = 2
    Bit position 0 = 1
    Match the PID's Bit Position and RAW value and use
    iff(RAW({GM.STATE00})&bit position,1,0)
    Blacky explains it better here.
    Why we need to go through this is a mystery to me,
    it would be nice to have them defined in a way so they appear in the
    The iff,& and bits operators can be a handful for some people
    to understand. (like myself)
    I recently discovered you can make a calc_pid for frame counts and
    filter out/in a certain section of a log by frame numbers.
    Call me slow.
    LC-1 WBO2
    For example, bit 5 can be extracted using either of these:
    iff(RAW({GM.STATE02}) & 32, 1, 0)
    RAW({GM.STATE02}) / 32 & 1
    RAW({GM.STATE02}) >> 5 & 1
  1. ECM in unknown state :(
    By SmokinDuradog in forum General (Diesel)
    Last Post: September 2nd, 2009, 02:48 AM
  2. TCM in unknown state
    By Sparky8370 in forum General (Diesel)
    Last Post: July 2nd, 2008, 09:28 AM
  3. Ecm in unknown state
    By HotRodSS in forum Duramax LB7
    Last Post: July 1st, 2008, 09:34 PM
  4. State PID Question
    By Black02SS in forum General
    Last Post: March 15th, 2006, 04:36 AM
