I have a 2001 trans am. I installed a cam and I was trying to tweak my base airflow (when cold) and then adjust my other airflow tables as necessary to get my idle better. It is not a big cam, I just haven't tweaked my airflow tables enough.
where/what table is the base airflow.
Right now I see Desired Airflow, Airflow Parked, Startup Airflow Correction, Startup friction airflow correction.
What all tables/parameters are involved in Startup airflow & cold start airflow?
-Stevo
