2011 LML 3500HD CC D/A 4x4
2006 LBZ 3500 CC D/A 4x4 Sold
2001 LB7 2500HD D/A 4x4 Sold
I installed switches on, built tunes for, and tuned 2 LBZs today. They both worked perfectly with no problems.
i cant figure out how to get build 99 i have build 88 and cant find an update??? help
2006 Chevy Ext Cab SB 2500 LBZ 4x4 EFI LIVE w/ Turbo brake
5" stacks egr blocked no kitty 285/70/17 nitto terra grapplers fass pump custom air intake tru trac diff in rear water/meth inj. race fuel valve
2001 Chevy Std cab 12' ultility bed with pipe rack 3500 2wd LB7 with 6 spd manual custom exhaust system and ppe boost increase valve
Duramax ROCKS
The first post in this post has the link to the new files.
Brian
2007.5 GMT-900 Chevrolet Silverado 2500HD CC/LB LTZ 4x4 Summit White.
With the LMM Duramax 365hp/660tq, MW7 Allison 1000 6-speed
EFILive LMM DSP5 Settings, 500HP, 450HP, 400HP,Tow with Turbine Brake, and Stock HP.
UA Steamfitter, Local 136 Evansville, IN - Remember if you want to play you got to pay.
right on-csn't wait to try this once i get some pins!!
'07 LBZ Classic, BW S464 Turbo, EGR deleted, 3" IC piping, Trans-go, ATS 5-star converter, stock clutches
A very small flat jeweler's screwdriver works well. I think they make a tool for it.
2005/2007 DHRA Western Drag Champion
Bonneville A/DT & B/DT Land Speed Record Holder, 197mph best speed.
Casper - 05 GMC 2500 Dmax LLY 10.59 @ 129, 916rwhp
Big Blue - 04.5 GMC 3500SRW LLY 13.12 @ 104, 502rwhp sled puller
Wendy - 06 GMC 2500 LBZ 12.50 @ 107.5 First LBZ into the 12's. 542rwhp.
Blue Meanie - 02 Z06 11.40 @ 121 AFR H/C
465hp/1008tq---7/25/09---Dyno Day Fast SpecialtiesTuning by ME
