Yea Marc and I talked about the cam buy he was organizing, I wanted to get in but alas being a broke college student I didnt have the $$$ around for the blanks.
What I mean is you'll probably have to use a piggyback controller to control the fuel and spark once you get into boost. If you dont you'll have to set the spark and fuel to be what you want in the PCM so that the last tables it sees before the MAP maxes are what you want for fuel and spark. I think if you use the MAF you might be able to get a better handle on fuel and spark until you max it out, then I dont know what you can do.
