Results 1 to 3 of 3
Thread: Barometric TQ limits (LMM)
    Jan 2008
    Default Barometric TQ limits (LMM)
    The table B1128 in the LMM OS only has 2 rows and the same table in the LBZ OS's has 16 rows. Thought you should know Ross.
    These things happen from time to time, Bosch or GM decide to change table structures between models. The Duramax isn't too bad, the gas engines (E38, E67) are a nightmare between model years, tables disappear, tables are added and existing ones change structure.
    This is a case of the table just changed structure. They must have thought it didn't need the resolution the LBZ had.
    Jan 2008
    oh wow! ok just checking...
  1. LLY MAF table limits
    By Cougar281 in forum Duramax LLY
    Last Post: June 30th, 2010, 11:55 AM
  2. Barometric Pressure Torque Limit B1128?
    By Mad Maxx in forum Duramax 06 LLY / 06+ LBZ & LMM
    Last Post: February 13th, 2010, 04:38 PM
  3. EFI hard limits B0202
    By sweetdiesel in forum Duramax LB7
    Last Post: January 23rd, 2010, 03:47 PM
  4. r.p.m. limits
    By smokethis in forum Duramax LLY
    Last Post: November 28th, 2008, 08:23 PM
