Results 1 to 10 of 19
Thread: Version 7.3
    Sep 2005
    Default Version 7.3
    Well I started using 7.3 today and as I loaded my tune, I got the following message;
    Engine Calibration.Fuel.Cranking
    {B0106} Crank:Run Blend Ratio, was out of range when loaded.
    Engine Calibration.Fuel.Mixture
    {B3601} Ratio of Air to Fuel for Stoichiometry, was out of range when loaded.
    The only value it would let me put in as AFR is 1! I had to reflash my PCM using 7.2 sine it would not let me put in AFR of 14.63
    Please advise
    2002 GMC Sierra ECSB
    Turbonetics T7675 6lbs boost, 42lb injectors, Single 4 inch exhaust with Hi-Flow Cats, 6.0 swap, Comp Cam LS9 Cam, EFIlive Tune, E-fans, Snow Performance Meth Kit, soon to add KB Boost a Pump,
    Oct 2004
    Check the Display Properties for AFR in the Tune tool. It can be displayed as either the actual AFR or the EQ ratio. If you are displaying the EQ ratio then 1 = 14.63 AFR.
    Andrew
    EFILive Crew
    Sep 2005
    I rechecked and it was AFR. My truck would not start so I reloaded 7.2 and it worked fine. SOS. I wan to use 7.3 but I need this solved.
    This may be the cause of the problem:
    http://www.efilive.com/forum/viewtopic.php?t=2053
    Sep 2005
    That fixed it. Thanks for the quick response. It makes buying the software worthwhile.
    Can anyone explain this one. It only ocurred with the new version.
    Transmission Calibration.Trans Pressures
    {D0701} Base Pressure 1->2 Shift, contained one or more out of range values when loaded.
    {D0702} Base Pressure 2->3 Shift, contained one or more out of range values when loaded.
    {D0703} Base Pressure 3->4 Shift, contained one or more out of range values when loaded.
    The new version checks for sane values in all calibrations.
    The old version did not. Those "out of range" values were simply ignored in the previous version.
    Lifetime Member ZL1Killa's Avatar
    May 2005
    i have updated my 01 cal and tun files to the new ones and I'm still getting this and it won't let me change it. Should I switch to a different OS such as an 02??
    01 T/A WS6 #4984 STOCK 342HP and 352TQ [/b]MODS:Too many to list, PM...funny rear mount.. father/son build.
    [Quote :ur car is sneezing!!!!]
    I KNOW KUNG FU.
    My STS build: http://www.ls1tech.com/forums/showthread.php?t=631954
    453HP 475TQ @6psi
    .....CAM'd, IC'd, and 7psi'd #'s coming.....
    Quote Originally Posted by jamesbond2509
    {D0703} Base Pressure 3->4 Shift, contained one or more out of range values when loaded.Cheers
    These out of range values are for the Performance Mode shift pressures,
    and they're out of range because your car does not use Performance Mode
    and GM set them to some large value (255).
    [Your truck doesn't have a Performance/Tow/Haul switch on your console, right...?].
    So EFILive Tune Tool rounds the out of range values down to the maximum value that the PCM allows.
    So, no worries.
    May 2005
    Quote Originally Posted by ZL1Killa
    i used the 01 custom cal and 01 custom tun to update it but it didn't change anything
    I KNOW KUNG FU.
    453HP 475TQ @6psi
    When you load your *.tun file what is the name, date and version of the *.cal file that is displayed in the first tab page of the PCM Info window?
    The version should be V7.7 or later and the date should be Oct 04, 2005 or later.
  1. Version 7.4 won't go away
    By 01Z in forum FlashScan V1
    Last Post: October 3rd, 2009, 10:20 AM
  2. LS1 version 2
    By ws6togo in forum Lounge
    Last Post: April 19th, 2006, 05:31 AM
  3. Anyone used Version 7.3 yet?
    Last Post: August 15th, 2005, 01:36 PM
