Results 1 to 4 of 4
Thread: Problem licensing PCM - EFI Live crashes Please HELP!
    Oct 2005
    Default Problem licensing PCM - EFI Live crashes Please HELP!
    Scenario - dmax LB7. trying to license the PCM. truck is stock. using efilive 7.5.5 build 88. bootblock 2.06.02. firmware 2.06.14. i have 4 total vin licenses. 3 are used. 1 avail.
    i read the cal from the pcm no problem. go to flash and it says not licensed so i turn truck off, wait for counter, click license button. it says something like "searching for flashscan v2" for less than one second then the whole program disappears (closes). no error message, just gone. tried it multiple times. restarted efilive, restarted laptop, disabled anti-virus and anti-spyware, power cycled the v2, tried it with truck ignition on as well as off.
    all same resuilt. never had this problem before. any ideas?
    thank you
    2002 Chevy D/A Summit White CC/SB
    Best E.T. 13.20 @ 99.875 #2 only, 11.675 @ 115.565 w/ NOS - 7300 lbs. Race Weight
    480HP/1030TQ #2 Only
    619HP/1240TQ NOS
    I pm'd Tech Support.
    Oct 2005
    Thanks to idahorob.. i went ahead and download the latest pre-release version 7.5.6 and upgraded my v2's firmware along with everything else in the upgrade doc. now i'm able to do it. not sure what the problem was, but at least its fixed!
    thank you!
    619HP/1240TQ NOS
    Ok, it's all fixed now...
  1. EFI Live V2/USB Comunication Problem
    By castewart in forum Duramax LB7
    Last Post: May 21st, 2009, 09:55 AM
  2. Need help licensing my PCM
    By Snakeaterz06 in forum General (Petrol, Gas, Ethanol)
    Last Post: May 10th, 2009, 07:58 AM
  3. Licensing
    By Biggsy in forum FlashScan V2
    Last Post: February 6th, 2007, 02:14 AM
  4. Efi Live Tuning Problem,, Need Help
    By Boll Curlee in forum General (Petrol, Gas, Ethanol)
    Last Post: November 18th, 2006, 07:43 AM
