I even used a stiffer wire than copper and i didn't need tools either.
465hp/1008tq---7/25/09---Dyno Day Fast SpecialtiesTuning by ME
I was inserting the pin in incorrectly, if you put in in right, it should slide right in there.
2011 Chevy 2500HD LML 4x4 LTZ-Black
-H&S Mini Maxx | MBRP 5" w/Muffler | 4" Rancho Lift | BMF REPR 20x9 DM | Mickey Thompson ATZ P3's 35/12.50's.
2012 VW Jetta TDI - Daily Driver.
SOLD - 06 LBZ
EcoDieselRam Forum
2007 CC/SB 4WD, McRat EFI Live, Trans, Trans Cooler and C3 clutch oiling mod by Mike L., SD Sleeves, SoCal Diesel
2002 CC/DRW 2WD, McRat EFI Live, Trans, Trans Cooler and C3 clutch oiling mod by Mike L., SoCal Diesel
I was able to use the wire itself to push with and it easily slid in. It went in quite a ways before they will lock in place.
If you dont get frustrated it will go nicely lol.
I can see a paper clip helping a ton. lol
12 Second LMM
I knew it...Just worked 5 all-nighters, 16 hours each shift...Came home, mixed up a few cocktails and started on my DSP5 install...Mounted switch, ran harness thru the firewall and pushed both pins in with needle nose and eyeglass screwdriver in about 20 minutes...I'm half Russian, so vodka is a good thing![]()
Will LBZ DSP be released as a normal update anytime soon? I haven't wanted to go through the steps to "patch" it for fear of goofing something up.
edit: ok, I think I figured it out. If (when) I find out I goofed up I'll be sure to yell for help!
