Page 5 of 8 FirstFirst ... 34567 ... LastLast
Results 41 to 50 of 75
Thread: LBZ DSP Beta1 Release
  1. #41
    Jan 2008
    I even used a stiffer wire than copper and i didn't need tools either.
  2. #42
    Jul 2004
    Quote Originally Posted by fire0021 View Post
    Not verry hard even for some one like me with big ole hands or at least mine wasent.
    Did yours have 2 grey wires? I think there's a couple of people making these and the stiffness of the wire can make it easier or harder.
    Ira
  3. #43
    Apr 2007
    I was inserting the pin in incorrectly, if you put in in right, it should slide right in there.
    2011 Chevy 2500HD LML 4x4 LTZ-Black
    -H&S Mini Maxx | MBRP 5" w/Muffler | 4" Rancho Lift | BMF REPR 20x9 DM | Mickey Thompson ATZ P3's 35/12.50's.
    2012 VW Jetta TDI - Daily Driver.
    SOLD - 06 LBZ
    EcoDieselRam Forum
  4. #44
    Sep 2006
    Quote Originally Posted by 8100 Power View Post
    I thought I had mine "clocked" properly and I was sober...
    Heck, maybe that was the problem
    2007 CC/SB 4WD, McRat EFI Live, Trans, Trans Cooler and C3 clutch oiling mod by Mike L., SD Sleeves, SoCal Diesel
    2002 CC/DRW 2WD, McRat EFI Live, Trans, Trans Cooler and C3 clutch oiling mod by Mike L., SoCal Diesel
  5. #45
    Feb 2008
    I was able to use the wire itself to push with and it easily slid in. It went in quite a ways before they will lock in place.
    If you dont get frustrated it will go nicely lol.
    I can see a paper clip helping a ton. lol
    12 Second LMM
  6. #46
    Sep 2007
    Quote Originally Posted by Ira View Post
    Ira
    Ira I got my switch from you so I belive there grey LOL dont remember but the wire was fairly stiff that may be why it was easier for me then others?
    Tommy
  7. #47
    Sep 2006
    I knew it...Just worked 5 all-nighters, 16 hours each shift...Came home, mixed up a few cocktails and started on my DSP5 install...Mounted switch, ran harness thru the firewall and pushed both pins in with needle nose and eyeglass screwdriver in about 20 minutes...I'm half Russian, so vodka is a good thing
  8. #48
    Aug 2009
    Will LBZ DSP be released as a normal update anytime soon? I haven't wanted to go through the steps to "patch" it for fear of goofing something up.
  9. #49
    Jan 2008
    Quote Originally Posted by ILVSMOG View Post
    There's not much to mess up. just DL the zip file and replace the existing .calz files with the new ones. And make sure you are using 7.5.6 build 99.
  10. #50
    Aug 2009
    edit: ok, I think I figured it out. If (when) I find out I goofed up I'll be sure to yell for help!
  1. LMM DSP Beta1 Release
    By GMPX in forum Duramax 06 LLY / 06+ LBZ & LMM
    Last Post: December 19th, 2009, 11:20 AM
  2. EFI not same release as V2?
    By RPM Motorsports in forum General (Petrol, Gas, Ethanol)
    Last Post: June 20th, 2008, 05:57 PM
  3. Pre release 7.5.1
    Last Post: October 4th, 2007, 08:55 PM
  4. New release 533
    By eboggs_jkvl in forum FlashScan V2
    Last Post: July 12th, 2007, 02:34 AM
