Page 4 of 5 FirstFirst ... 2345 LastLast
Results 31 to 40 of 41
Thread: Imperial pids for BBL?
  1. #31
    Post your Options.txt file... is it the latest one that came with V8 build 75...?
  2. #32
    Jun 2009
    the unit was purchased on nov 2008 but it did updates as soon as i installed it on the new pc
    i might go ahead and uninstall and reinstall first just in case something went wrong, maybe that's why it wouldn't install drivers for the v2 as well
    if that doesn't cure it, I will post my options.txt file
    71 Chevelle, LS1/4l60e, EPS 230/238 113+2, hand ported 799s, ported Fast 90/90, Doug's headers, 3.42 12 bolt
  3. #33
    Default Latest V2 updates...
    You can download/install the latest versions from here: showthread.php?p=105679#post105679
  4. #34
    Apr 2008
    Build 75 had a bug that did not give you a choice there. Had to use a previous version or use the latest public beta versions of V7.5 and V8 for the fix.
    Brian
    2007.5 GMT-900 Chevrolet Silverado 2500HD CC/LB LTZ 4x4 Summit White.
    With the LMM Duramax 365hp/660tq, MW7 Allison 1000 6-speed
    EFILive LMM DSP5 Settings, 500HP, 450HP, 400HP,Tow with Turbine Brake, and Stock HP.
    UA Steamfitter, Local 136 Evansville, IN - Remember if you want to play you got to pay.
  5. #35
    Senior Member acomp917's Avatar
    Jan 2010
    Hello All,
    I'm new to EFI Live. I have read and learned a lot. I have read two threads dedicated to changing some of the metric PID's to imperial units. I cannot tell if 8.1.2.84 is capable of it or not. I can get to the properties menu, but there is no pull down to change it. At this point I do not have the ability to edit the options.txt file.
    Could I get a little guidance on this one
    TIA,
    S
  6. #36
    Have a look at the attached pic... the pull down should work, it will contain the "alternate" units.
Name:	pid properties popup - custom.png
  7. #37
    Jan 2010
    Thanks again joecar,
    Wow do I feel dumb. I did not think to try that I read and worked at it for an hr. You must get real tired of answering the same questions over................
    How do you keep track of it? If it is a file, it would be VERY useful as a guide for others.
    S
  8. #38
    Hah, don't feel dumb, software (not to mention tuning) is an 11 on a complexity scale of 1-to-10.
    I have some screenshot images I saved, I was thinking of making a pic tutorial... see attached...
Name:	S&T - Black Box Settings - Scan Settings.png
ID:	7147   Click image for larger version.
Name:	S&T - Black Box Settings - Tune Settings.png
ID:	7148   Click image for larger version.
Name:	S&T - Black Box Settings.png
ID:	7149   Click image for larger version.
Name:	S&T - Device Setings - Serial IO.png
ID:	7150   Click image for larger version.
Name:	S&T - Device Settings - BBL.png
  9. #39
    More...
ID:	7152   Click image for larger version.
Name:	pidlist properties.png
ID:	7153   Click image for larger version.
Name:	pidlist properties popup.png
ID:	7154   Click image for larger version.
Name:	pid properties.png
ID:	7155   Click image for larger version.
Name:	pid properties popup - alarm.png
  10. #40
    Jan 2010
    joecar,
    Those pics are an outstanding way to instruct setting up BBl. I found the first ones... and I figured out how to accomplish the last ones. I was missing that one that displayed the units config.
    You should make those available for everyone to easily find. I'm beginning to learn a few things. MOST of the info is in the forums. There is a LOT to learn. some of it changes quickly. And figuring out how to make it easily available and administrate it seems like a monumental task.
    Do you think "we" as a group will ever gather on terms to wiki this info into a GOOD beginner guide? I'm so strung out from learning, I have nothing to apply to learning how to create a wiki or other to help beginners. Hell, I still can't map a good flow chart in order to structure the publication.
    S
  1. Question displaying Imperial during BBL
    By Brian1 in forum FlashScan V2 BB Logging
    Last Post: November 8th, 2009, 02:15 PM
  2. Imperial vs Metric
    By killerbee in forum General (Diesel)
    Last Post: September 3rd, 2009, 09:16 AM
  3. Changing Pids to Imperial??????
    By turboolds in forum FlashScan V2 BB Logging
    Last Post: June 17th, 2009, 10:17 AM
  4. Imperial MAP values seem backwards
    By kp in forum General
    Last Post: March 9th, 2005, 06:40 PM
  5. Imperial MAF units in the V7 scan tool
    By XLR8NSS in forum General
    Last Post: February 26th, 2005, 11:38 PM
