Results 1 to 5 of 5
Thread: DTC's from non-GM vehicles
    Default DTC's from non-GM vehicles
    Should the current firmware for the V2 support pulling DTC's from CAN-based non-GM vehicles? If so, would it be just powertrain codes, or would it be powertrain, body, chassis and comms like the GMs?
    I tried pulling codes from a 2004 Taurus, and the thing is it got some data, but was unable to get codes from the ABS module. It also was able to pull data using the "Record All Diags" (see below). Another thought, the "Record All Diags" requires you to slect a PID list... Any chance of having it run like it used to where it just pulled all data so it'll work with non GM CAN-based vehicles?
    Code:
    [ECM INFO]
    VIN=Unknown
    OS=Unknown
    Stream=LLY
    [ECM CVN]
    0=AE36C2F3
    [System Readiness Tests]
    MIL=OFF
    DTC_CNT=0
    MIS=Ready
    FUEL=Ready
    CCM=Ready
    CAT=Ready
    HCAT=N/A
    EVAP=Ready
    AIR=N/A
    ACRF=N/A
    O2S=Ready
    HTR=Ready
    EGR=Ready
    [DTCS]
    ; No DTCs detected.
    [MODE06]
    ;ID    MinLimit    Value MaxLimit Units    Result
    0101.0=  0.0000,  0.4499,  7.9953,V       ,OK    ,"Rich to Lean Sensor Threshold Voltage"
    0180.0=  0.5000,  0.8062,  7.9953,V       ,OK    ,""
    0181.0=     465,     948,    3000,        ,OK    ,""
    0201.0=  0.0000,  0.4499,  7.9953,V       ,OK    ,""
    0281.0=     220,     529,    3000,        ,OK    ,""
    0501.0=  0.0000,  0.4499,  7.9953,V       ,OK    ,"Rich to Lean Sensor Threshold Voltage"
    0580.0=  0.5000,  0.8340,  7.9953,V       ,OK    ,""
    0581.0=     465,     958,    3000,        ,OK    ,""
    0601.0=  0.0000,  0.4499,  7.9953,V       ,OK    ,""
    0681.0=     220,     516,    3000,        ,OK    ,""
    2180.0=   0.000,   0.090,   0.699,        ,OK    ,""
    2280.0=   0.000,   0.074,   0.699,        ,OK    ,""
    3180.0=  -2.266,   0.205,  32.767,kPa     ,OK    ,""
    3181.0= -32.768,   0.205,   2.260,kPa     ,OK    ,""
    3184.0= -32.768,   0.548,   4.836,kPa     ,OK    ,""
    3185.0=   1.494,   6.611,  32.767,kPa     ,OK    ,""
    3A80.0=    0.00,    0.00,    0.00,Pa      ,OK    ,""
    3A81.0=    0.00,    0.00,    0.00,Pa      ,OK    ,""
    3A82.0=    0.00,    0.00,    0.00,Pa      ,OK    ,""
    3B80.0=-8192.00,  324.75,  609.75,Pa      ,OK    ,""
    3C80.0=-8192.00,   92.75,  214.75,Pa      ,OK    ,""
    A180.0=       0,       0,   19659,        ,OK    ,""
    A181.0=       0,       0,     655,        ,OK    ,""
    A182.0=       0,    1310,   19659,        ,OK    ,""
    A183.0=       0,       0,     655,        ,OK    ,""
    A184.0=       0,    3007,    9388,        ,OK    ,""
    A20B.0=       0,       0,   65535,        ,OK    ,""
    A20C.0=       0,       0,   65535,        ,OK    ,""
    A280.0=       0,       0,   19659,        ,OK    ,""
    A281.0=       0,       0,     655,        ,OK    ,""
    A30B.0=       0,       0,   65535,        ,OK    ,""
    A30C.0=       0,       0,   65535,        ,OK    ,""
    A380.0=       0,       0,   19659,        ,OK    ,""
    A381.0=       0,       0,     655,        ,OK    ,""
    A40B.0=       0,       0,   65535,        ,OK    ,""
    A40C.0=       0,       0,   65535,        ,OK    ,""
    A480.0=       0,       0,   19659,        ,OK    ,""
    A481.0=       0,       0,     655,        ,OK    ,""
    A50B.0=       0,       0,   65535,        ,OK    ,""
    A50C.0=       0,       0,   65535,        ,OK    ,""
    A580.0=       0,       0,   19659,        ,OK    ,""
    A581.0=       0,       0,     655,        ,OK    ,""
    A60B.0=       0,       0,   65535,        ,OK    ,""
    A60C.0=       0,       0,   65535,        ,OK    ,""
    A680.0=       0,       0,   19659,        ,OK    ,""
    A681.0=       0,       0,     655,        ,OK    ,""
    A70B.0=       0,       0,   65535,        ,OK    ,""
    A70C.0=       0,       0,   65535,        ,OK    ,""
    A780.0=       0,       0,   19659,        ,OK    ,""
    A781.0=       0,       0,     655,        ,OK    ,""
    Yes, we're working on making it work for all (most) CAN based vehicles.
    Nov 2005
    cool!! That would be awesome! Any chance that it could be made to work for all pre-CAN OBD2 vehicles? Even if its only the P0XXX universal emissions codes?
    12.9s @ 108 mph
    many thanks to Ross and Paul
    No, unless those vehicles use either the VPW (GM, pre-CAN) or ALDL (GM OBDI) protocol's. For example FlashScan does not support PWM (Ford, pre-CAN) or SCI (Chrysler, pre-CAN) protocols.
    For FS V3 maybe? Or am I jumping the gun a little bit? Haha, Ill be a happy clam if I can get this dumb P10 to AutoVE and BBF. The E67 will be easy, its the other stuff thats not :(
  1. 2 vehicles? Both work?
    By MNBlade in forum General
    Last Post: November 19th, 2009, 04:59 PM
  2. TCM supported vehicles
    By GMPX in forum 4speed RWD/FWD Transmission Tuning (incl T42)
    Last Post: January 4th, 2007, 11:47 AM
  3. Supported Vehicles
    By Blacky in forum Lounge
    Last Post: December 1st, 2006, 05:16 PM
  4. Does V2 connect to VE HSV vehicles?
    By Acer in forum General (Petrol, Gas, Ethanol)
    Last Post: November 18th, 2006, 10:36 PM
  5. What vehicles will be supported?
    By Merlin in forum General (Petrol, Gas, Ethanol)
    Last Post: July 25th, 2004, 04:56 PM
