Results 1 to 10 of 95
Thread: E38 / E67 Custom OS Beta release
Threaded View
    Dec 2007
    Default E38 ECM Connector Details
    A few pics to show how the wire/terminal is added to the E38 body connector:
    Body or J1/X1 Connector for E38 ECM. It is the 73 pin connector. Note the arrow to cavity 5. Most unused cavities have either a blue plug or a black plug that is molded as part of the connector. Cavity 5 has the molded in plug. The cavity is blocked with this plug.
Name:	E38 J1 Body Connector 1A.jpg
    E38/E67 .64 Series Terminal with wire
Name:	E38 Terminal 2.jpg
    Flipside of connector - terminal side where it plugs in to ECM socket.
Name:	E38 J1 Body Connector 3.jpg
    Small screwdriver is used to break the black molded in plug loose. Push on the edge of the plug alongside the cavity wall for best leverage. It should break loose without too much pressure if you push in the right place.
Name:	E38 J1 Body Connector 3A.jpg
    If your connector has the molded in black plugs, they need to be removed from the terminal area underneath the terminal seperator. Use a small screwdriver at each end of the seperator to leverage it out. Cable end:
Name:	E38 J1 Body Connector Socket Side 4.jpg
  1. 98 Controllers Missing from New Beta Release
    Last Post: March 23rd, 2008, 11:03 AM
  2. 3/18/08 What do I need to have to be prepared for the new beta release
    By Kevin Doe in forum FlashScan V2 BB Logging
    Last Post: March 23rd, 2008, 03:56 AM
  3. V2 Black Box Logging - Beta Release
    By Blacky in forum FlashScan V2
    Last Post: November 27th, 2007, 09:11 PM
