Page 2 of 10 FirstFirst 1234 ... LastLast
Results 11 to 20 of 95
Thread: E38 / E67 Custom OS Beta release
    Apr 2008
    Default E38 Connector info
    As promised the detailed connector info of C1 and C2
    I also have a .pdf (with 5MB too big to upload here) with all the connector pin descriptions. If anyone needs this just let me know I can email it.
    Harald
ID:	6699   Click image for larger version.
    If nobody has done it before, somebody has to do it....
    1997 Tahoe 2dr 4WD
    2002 Alfa Romeo Sportswagon 2.0 JTD
    1982 Deutz Intrac 2004A
    2003 friesian Horse " Henry"
    The E38 connectors are Delphi.
    the two E38 have the following part No: (sorry the T42 connector is also listed..)
    Part Number, Description,
    13511426 "80 Way Gray 0.64 Sealed Female Connector Assembly",
    15463921 "49 Way Black GT 280 Micro 64 Sealed Female Connector Assembly"
    15499466 "73 Way Black 0.64 2.8 Sealed Female Connector Assembly"
    the different pins are:
    quote above:
    Hey guys, all of the information that I have found was that the E38 ecm connectors were made by MOLEX? When you did your E38, did you actually use DELPHI connectors?
    Just one guy tryin' to make a difference
    Apr 2008
    just copy the connector part No and paste them in the search box on the Delphi webpage... you will see the correct E38 connectors.
    Harald
    1997 Tahoe 2dr 4WD
    Aug 2008
    Check this thread out for E38 connector views & pinouts....http://forum.efilive.com/showthread.php?t=11845
    FLASHSCAN V2 & AUTOCAL
    Dec 2007
    Default E38 ECM Connector Details
    A few pics to show how the wire/terminal is added to the E38 body connector:
    Body or J1/X1 Connector for E38 ECM. It is the 73 pin connector. Note the arrow to cavity 5. Most unused cavities have either a blue plug or a black plug that is molded as part of the connector. Cavity 5 has the molded in plug. The cavity is blocked with this plug.
Name:	E38 J1 Body Connector 1A.jpg
    E38/E67 .64 Series Terminal with wire
Name:	E38 Terminal 2.jpg
    Flipside of connector - terminal side where it plugs in to ECM socket.
Name:	E38 J1 Body Connector 3.jpg
    Small screwdriver is used to break the black molded in plug loose. Push on the edge of the plug alongside the cavity wall for best leverage. It should break loose without too much pressure if you push in the right place.
Name:	E38 J1 Body Connector 3A.jpg
    If your connector has the molded in black plugs, they need to be removed from the terminal area underneath the terminal seperator. Use a small screwdriver at each end of the seperator to leverage it out. Cable end:
Name:	E38 J1 Body Connector Socket Side 4.jpg
    Dec 2007
    Default E38 Connectors continued 1...
    Continued:
    Leveraging the other end to the cable side out. The seperator needs a light push upward to unclip it at each end.
Name:	E38 J1 Body Connector Socket Side 5.jpg
    Terminal side view.
Name:	E38 J1 Body Connector Terminals Internal Plug 5A.jpg
    Look into cavity 5 for the molded in plug and remove it with a small tool. Though some connectors may have no plugs, and open seals, this is unlikely.
Name:	E38 J1 Body Connector Terminals Internal Plug 5B.jpg
    Terminal on the way in to the right cavity. Make sure it is oriented the right way around. There is an open section in the terminal which needs to engage a locking tang once pushed in.
Name:	E38 J1 Body Connector Terminal In 7.jpg
    Terminal all the way home on the connector side. Note a "click" when it is in the right place as the tang clicks in to the terminal.
Name:	E38 J1 Body Connector Terminal All The Way In From Sock Side 9.jpg
    Dec 2007
    Default E38 Connectors continued 2...
    Connector with terminal seperator re-installed. Only goes one way, with different sized tongues on each end, and the ground terminal.
Name:	E38 J1 Body Connector Keeper Back In 10.jpg
    E67 uses same connectors, but they only plug into an E67. Process is the same.
    If you are in the land downunder, and cant find any E38/E67 terminals, we have single wires with terminals crimped on. PM me.
    Trust this helps y'all.
    Oct 2005
    Very insteresting update ! I wish all that info was available when I
    was messing with that 07 Escalade to run on E85 about 2 years ago.
    2005 RCSB 2500HD GMC Sierra DURAMAX LLY
    1955 Chevy Truck 1st series, being restored
    2002 Mercedes C270 CDI
  9. #19
    Aug 2008
    Thats a cool step by step..
  10. #20
    Redline Motorsports
    Guest
    Nice job!
    Howard
  1. 98 Controllers Missing from New Beta Release
    Last Post: March 23rd, 2008, 11:03 AM
  2. 3/18/08 What do I need to have to be prepared for the new beta release
    By Kevin Doe in forum FlashScan V2 BB Logging
    Last Post: March 23rd, 2008, 03:56 AM
  3. V2 Black Box Logging - Beta Release
    By Blacky in forum FlashScan V2
    Last Post: November 27th, 2007, 09:11 PM
