Results 1 to 10 of 12
Thread: ECM relearn procedure and VIN
    Default ECM relearn procedure and VIN
    Using an ECM from another vehicle, should I expect to be able to perform the relearn, even if the VIN has not been changed on the ECM?
    Custom Tuning Services
    Yes because the VIN has nothing to do with the security.
    so I thought. Just having trouble with a field re-vat. He probably just having difficulty following directions.
    I sent a new ECM, new tuning, and the truck just won't accept it. He says the truck will turn over, but won't start.
    Any idea out there?
    What does it mean if a new ECM will turn the truck over, but not start?
    Dec 2005
    It means the ecm is probably OK but the VATS is not.
    He will have to do a hard re-learn.
    www.mscservices.net
    Fixed it. Some people just will not turn the ignition off, but rather to accessory...I tried to make this point, but for some it doesn't hit home.
    Quote Originally Posted by Jeavaiz09 View Post
    I bought an ecm/tcm for a member with a vector tune for 07 tbss, do I need to send this to vector to have my vin matched to it or just do the security relearn and case learn?
    You can just do the security and CASE relearns, it should work fine. But if your emissions test center looks at the VIN in the ECM and compares it to your actual VIN you will fail the emissions test. I know Vector locked their tunes for a while, I thought I read something about they do not do that anymore. If yours is an unlocked one, you can have someone with EFILive simply change the VIN. No license burned either.
    Aug 2007
    I also leave the door open too, so that the delay off shuts off as soon as the key is turned to the off position, not sure if that is tied to the pcm circuits, but I took no chances when doing things like that LOL...
    2005 chevy silverado, duramax tuned with efilive
    1997 Saturn sc2 turbo, tuned with megasquirt on e85
    2000 s-10 turbo'd tuned with efilive on e85
    Quote Originally Posted by chevy052500hd View Post
    Interesting, if I do this with any P10 TrailBlazer it always messes up the flash. I have to shut the doors, kill the AHLs, radio/HVAC off then it works fine every time (unless there's an aftermarket HU messing up the data comms).
  1. Weird procedure issues? Why???
    By Airman in forum FlashScan V2
    Last Post: January 31st, 2008, 08:06 AM
  2. Procedure for changing to different year OS
    By dropped2000 in forum General (Petrol, Gas, Ethanol)
    Last Post: September 23rd, 2005, 07:56 AM
  3. Auto Tune Procedure
    Last Post: May 27th, 2005, 01:27 PM
  4. Procedure for turning off MAF and forcing open loop for SD?
    By AllCammedUp in forum General (Petrol, Gas, Ethanol)
    Last Post: May 4th, 2005, 12:10 AM
