Results 1 to 10 of 12
Thread: Err 1400, Invalid Window Handle
    Lifetime Member Mr. P.'s Avatar
    May 2007
    Default Err 1400, Invalid Window Handle
    OK this has happened a couple times to me now -
    I am using EFILive 7.5.100, and upon closing the Tuning tool I get two back-to-back error windows saying error 1400, Invalid Window Handle.
    Mr. P.
    Nov 2006
    I had that error yesterday too.
    The PC crashed afterward, I thought it was a Windows issue.
    LC-1 WBO2
    Its been happening to me since build 99, I havent upgraded to 100 yet because of time constraints.
    W7 Ult x64
    I've seen it too, but I can't reproduce it reliably yet :(
    If anyone can generate a sequence of steps that will cause it to happen consistently please let me know.
    May 2007
    I think the Scan tool and Tune tool have to be open at the same time - i.e. open the tune tool and load a log file, then open the scan tool and establish the cross-window data linking, then close the tune tool. In my case I have one instance of the Scan tool running and 3 instances of the Tune tool open, and when I closed the Tune tool it got all pissed-off...
    May 2007
    Also got an Invalid Floating Point Operation trying to manipulate the 3D chart display with the right mouse button in {B3647}.
    Quote Originally Posted by Mr. P. View Post
    Thanks, I'll check it out.
    I'm about to post up a new version (later today) that fixes the Invalid Floating Point error. Its a bug caused by incorrect magnification settings on the 3D surface.
    Nov 2006
    After the auto update it still shows build 100,
    is this OK?
    LC-1 WBO2
    Mine shows 101...
    but in the last few days I have been thru several uninstalls and registry entry deletions (in my attempt to define a particular bug, mentioned above).
  1. System Error- code 1400
    By Tarkstoys in forum FlashScan V2
    Last Post: April 17th, 2010, 07:54 PM
  2. Programming Silver PCM from 2001 S-10 4.3L to handle 97 Vortec
    By onegonewild in forum Gen III V8 Specific
    Last Post: May 1st, 2008, 02:42 AM
  3. Menus: Window.
    By curtbriggs in forum General (Petrol, Gas, Ethanol)
    Last Post: February 28th, 2005, 05:00 PM
