full reflash takes 40 mins, whats going on with my box. before i could flash in under 4 minutes or so
1998 Camaro Z28, forged ls2 sts turbo GtsT76, fmic
1999 Firebird, forged ls1 procharger p1sc ls9 cam fmic
1981 El Camino, 5.3 LSX carb, msd 6010
2011 2SS
Does it succeed...?
What happened between when it went fast and when it started going slow...?
Check that you have the "Use high speed" box checked.
Might pay to send through the debug as described here (http://www.efilive.com/index.php?opt...111&Itemid=121). Perhaps your PCM has bad flash?
Andrew
EFILive Crew
yes it did succed and the high speed box is checked
2011 2SS
Didn't you have a problem with FW, is that fixed?
LC-1 WBO2
fixed but flash takes forever
2011 2SS
Have you tried with a different computer?
Maybe a COM setting?
LC-1 WBO2
same laptop, com set to usb v2
2011 2SS
I meant try using another laptop/PC to see if it will flash correctly.
I remember flashing my stock PCM, the 3 minutes or so it took was an eternity.
I can't imagine waiting 40mins.![]()
LC-1 WBO2
Do what Tordne said in post #3.
Do you remember the events just prior to this happening...?
