Anyone who replaced these bushings, what did you replace them with...?
Strano has these
Camber correction/Offset Upper Control arm kit
They are a limited run tho.
LC-1 WBO2
Nah... I don't want those, they're too expensive/limited... I'm looking for off-the-shelf... thanks tho for pointing those out.
The stock bushings are "slotted" rubber...
the only other ones I know of are the Moog ones, and I'm wondering if they're solid rubber.
Probably the only other choice for what you want.
Or you can go to a dealership.
If you go to a stealership ask if you can get them for free
seeing how you gave GM your tax dollars.
LC-1 WBO2
The Moog ones are slotted also... look carefully:
http://www.power-21.com/federalmogul...D%20VIN%20G&t=
You can always replace the upper with a aftermarket poly bushing.
Roy 98SSSSSS
I wanted to avoid poly...
the upper looks like it sees only pivoting-motion and no twisting-motion (like the rear lca's), so poly may be a good idea.
Thanks.
That would be theonly position I would advocate the use of poly. I use delalum bushes and the UCA from Global west since 1999. Pricey though.
Roy 98SSSSSS
