Results 1 to 5 of 5
Thread: Looking for a little clarifaction on a PDF file.
    Apr 2008
    Default Looking for a little clarifaction on a PDF file.
    Looking to see where one gets the needed firmware and bootblock files mentioned in this PDF to do an update based on the old firmware and bootblock versions one may have.
    http://download.efilive.com/Software/V8/Upgrading FlashScan.pdf
    I have not installed a copy of V8.1.2.80 on a clean machine but does it contain the following files.
    firmware V2.04.72.
    boot block to V2.05.08.
    firmware V2.05.21
    firmware V2.05.14
    I have the last too firmware versions I list but do not know if they are let overs over time or what.
    I do not have the boot block version mentioned so was wondering where one get that if they had and old enough flashscan that has never been updated to that point.
    I just updated a post I wrote a long time ago for setting up the flashscan V2 on Dieselplace forums. So I had the weekend off and enough time to update it to the newest public beta release how to. I get lots of PM of users asking how I did this or do that and figure this be the best way to get it all out there in one doc to help others. Someone ask me how to deal with one of the old firmware versions to update and I was lost since I did not have some of the versions mentioned in the PDF file.
    http://www.dieselplace.com/forum/sho...03#post3637103
    Thanks for your time and help.
    Brian
    2007.5 GMT-900 Chevrolet Silverado 2500HD CC/LB LTZ 4x4 Summit White.
    With the LMM Duramax 365hp/660tq, MW7 Allison 1000 6-speed
    EFILive LMM DSP5 Settings, 500HP, 450HP, 400HP,Tow with Turbine Brake, and Stock HP.
    UA Steamfitter, Local 136 Evansville, IN - Remember if you want to play you got to pay.
    Hi Brian,
    Get the bootblock and firmware from here: showthread.php?t=12587
    The current builds are V7.5.6.101 and V8.1.2.81.
    That page previously had 100 and 80... but those had problems, so that page was updated with 101 and 81.
    Here's a link to that pdf document: http://download.efilive.com/Software/V8/Upgrading%20EFILive.pdf
    Hint:
    when viewing the page linked to in post #2, go rightclick->Copy Link Location to get the link to the pdf...
    when you paste this it comes out like above (%20 replaces space).
    Also: if anyone's V2 has old bootblock/firmware: please refer them to the attached document.
    Apr 2008
    Thank you so much for the help. That should help very well. Ok I see one can leave the %20 to represent a space in the link thats good. The space was throwing my link of that one I had posted in my other post.
    Brian
    Feb 2026
    Thanks for sharing this PDF guide! It’s really helpful to see the step-by-step instructions for updating firmware and bootblocks. For anyone needing additional templates or official forms while working through these updates, I’ve found https://pdfguru.com/form-templates/letter to be a great resource for all kinds of letter templates. Following the instructions carefully and having the right files on hand makes the process much smoother. Always double-check versions before proceeding, and don’t hesitate to consult forums if something seems unclear.
  1. P12 PCM file
    By Chevy366 in forum IL6,IL5,IL4 Atlas Engines - P12 PCM
    Last Post: June 29th, 2009, 09:28 AM
  2. why would i get this red file?
    By JOHNGEAR in forum Forced Induction and Nitrous Oxide (N20)
    Last Post: February 13th, 2009, 05:25 AM
  3. cax file?
    By myws6formula in forum CAX Files
    Last Post: December 21st, 2008, 04:00 PM
  4. MAF .xls file
    Last Post: April 7th, 2006, 09:39 AM
