Hi guys, I'm a little confused on what my best course of action is with my setup. The car is a street rod and I originaly had a heads/cam 346 with a 98 computer and painless harness. I used LS1Edit to tune. Well this winter I changed the combo all around. I redid the engine lowering the compression and added twin 62mm turbos. I also purchased efilive V1 and repinned my harness to 99-02 config and installed a 02 computer.
Here are the car specs
346 9.5 - 1 compression
Dart 225 heads
80lb injectors
22x/23x .600" 114
twin precision 6265 62mm turbos
Th400 with transbrake and 4k stall converter
I'm only planning on running about 15 - 20psi. I'm guessing I should be using cos5. What should I do to get this thing fired up and start tuning? Should I add the cos first or wait till after I fire it up? Or should I try to find someone with a similar setup and use that as a base?
Thanks for any advise or guidance,
Frank
