last week I installed my dsp5 switch and full flashed the dsp file. I'm am really new to EFI LIVE and just wanted to start by correctly hooking everything up to BBL. I started by following the step by step instructions in the scan tool getting started pdf. When i connect to the truck choosing the lbz ecm and then it ran the OBDII emissions related test results. I went to the summary and found a red X next to dtc's. I double clicked it and stated with a red engine icon: left front driver or generic door ajar circuit open. code b2978 and it says it's on the TCM and will not clear??
It seems that all these test have to pass in order to do any type of logging.
I then went to the allison 6sp tcm and ran the dtc check and it came up with a gray engine emblem stating the same as the one on the ecm and would not clear either.
I hope this is clear enough
Brian
