Thanks so much!!!
So far so good.![]()
Thanks so much!!!
00 GMC,LQ4, Jarrett Faggart pistons, callies rods, Ebay studs, LS9 gaskets, 317's, KBRacing KIT, PT76/75, treadstone intercooler,Eboost2, dual walbro, FIC 75lb, br7ef, Trutrac, Shaftmasters Shaft, 3.5" DP w/4" magnaflow dumped, turbo blanket, Circle D 3200, Jake's built 4l80w/brake, hydroboost, EFILive v2,Lunati dual springs,222/226 cam, cal-tracs, QA1 front shocks, Street/strip Bogarts,Drum swap, Alky-control,MSD8733 936 HP to the tire DD.
I am pulling the EFI live out again after months of down time due to time and computer problems.
Can someone refresh my memory on getting my bootblock and firmware to show up on my V2. The directions from this thread don't help since they are from an old version. The above versions are the ones I assume I still have in my V2.
Thankks in advance!!!
You can see the BB & FW in the Firmware tab of EFILive Explorer or
press F4> F3> F1> scroll down on the V2 itself.
LC-1 WBO2
Thanks so much!!!
Looks like I am on the latest bootblock 2 06 02 .
Can I upgrade straight to the firmware to V2.06.012 from 2.06.06 or do I have to upgrade the ones in between one at a time until I get the latest. Just want to be sure I am doing this right!
Yes, latest bootblock is 2.6.2.
Latest firmware is 2.6.24.
Yes, you can go straight from 2.6.6 to 2.6.12 or to 2.6.24.
See here for latest 7.5.6.104/8.1.2.84 software: showthread.php?t=12834
