ScarabEpic22,
I'm not sure what you mean. Both .tun files match in the fans area. The heading is "no fans" that negates all of those settings. The trucks use belt driven fan.
On that flash advice... You have to flash the COS over any compatible controller, then flash the compatible calibration "into" the COS.
Careful about what you tell noobs, they(I) should learn correctly.
S
