Results 1 to 5 of 5
Thread: os12637084- unrecognized PCM
    Default os12637084- unrecognized PCM
    I have 7.5.5 build 88
    I get the Unrecognized PCM msg.
    I can't read the customers car. This is a 2010 Camaro M6.
    This is the first OS 12637084 that I have seen. I can't even read this OS from the Holden Crazy site.
    I must be missing something.
    Anybody??
    Aug 2008
    I think you need to update to 7.5.6 build 104
    Link: http://forum.efilive.com/showthread.php?t=12834
    FLASHSCAN V2 & AUTOCAL
    Yep, update to 7.5.6 build 104, 8.1.2 build 84, and update your V2 to the latest firmware provided with the downloads. Should get you up and running in a few mins!
    Thanks for the response
    I will load the update this weekend and test
    I updated to V7.5.6(build 106) and it appears to fix it.
    Thanks again
    XMAN
  1. Unrecognized PCM
    By Roadrunner in forum Gen III V8 Specific
    Last Post: July 2nd, 2008, 02:26 PM
  2. Unrecognized PCM
    By Rocketman69 in forum IL4, 97-01 PCM and 02+ P11 PCM
    Last Post: January 10th, 2008, 01:11 PM
