Page 1 of 3 123 LastLast
Results 1 to 10 of 23
Thread: Commanded AFR ≠ {B3601}
    Nov 2006
    Default Commanded AFR ≠ {B3601}
    gm.eqivratio = 1.000000
    {b3601} = 14.628573
    gm.afr = 14.627930
    diff = 0.000643
    I know the difference is minuscule but could this be a bug in the software?
    LC-1 WBO2
    Jul 2007
    {b3601} = 14.628573
    gm.afr = 14.627930
    diff = 0.000643
    I would think this would be affected by the source of GM.AFR. Startup, Cold, warm run, PE vs RPM. You didn't mention the conditions of the occurence. Maybe some interpolation going on..??
    Could it also be since the pc stores this data in 2 byte unsigned format (believe this is a 2 byte datalog param), vs floating point, I would wonder if the data stored and used for internal RAM calculations, is actually ever what we display in floating point and view for editing purposes.
    I checked a recent log I did and noticed a similar discrepancy, however I rarely use that value for tuning due to cam overlap.
    07 Silverado DMax Classic
    Nov 2006
    I'm not sure what gets lost here.
    When {GM.EQIVRATIO}=1, {GM.AFR}≠{B3601} it is a little richer.
    {GM.AFR} should be exactly the same as the value in {B3601} when {GM.EQIVRATIO}=1
    In short logged {GM.AFR} values are not what they should be even tho
    logged {GM.EQIVRATIO} values are.
    {GM.AFR} should be {B3601}/{GM.EQIVRATIO}
    Something is throwing it off and I see nothing in the .tun that would do that
    LC-1 WBO2
    I think GM.AFR and B3601 are represented differently (i.e. their binary representation) so you will get that small discrepancy.
    I would ignore GM.AFR and instead pay attention to GM.EQIVRATIO (and calculate BEN's on EQIVRATIO and WO2EQR1).
    Nov 2006
    Yes Joe I know
    I use my own EQ BEN and custom WBO2 AFR for reference,
    but this has always bothered me.
    It would not be an issue if commanded EQ was higher than 1.00
    that would explain why commanded AFR is a tick richer.
    Combine this with an improper WBO2 slope and it will cause a headache.
    LC-1 WBO2
    Jul 2007
    I found this post interesting and of some relation to yours:
    http://forum.efilive.com/showthread.php?t=13094
    The dyno datalog posted shows a steady GM.AFR of
    12.23. When you look at this PE vs RPM table, it "appears" the processor is actually adding the last different AFR to the current one and averaging the two. I would have thought that anything >= 2000 RPM would have been 12.19 AFR according to this PE VS RPM. Somehow this doesn't make sense to me,...
    0 13.037127
    400 13.003176
    800 12.946982
    1200 12.514335
    1600 12.268353
    2000 12.198419
    2400 12.198419
    2800 12.198419
    3200 12.198419
    3600 12.198419
    4000 12.198419
    4400 12.198419
    4800 12.198419
    5200 12.198419
    5600 12.198419
    6000 12.198419
    6400 12.198419
    6800 12.198419
    7200 12.198419
    Nov 2006
    IMO something is wrong with the {GM.AFR} PID.
    EQ1 should match {B3601}.
    LC-1 WBO2
    {b3601} = 14.628573
    gm.afr = 14.627930
    diff = 0.000643
    The math done in the PCM is performed using 16 bit fixed point precision. Some values in the above are only accurate to 1/1024.
    If a value (for example AFR) is represented as a value from 0 AFR to 63.999 AFR but is stored in the PCM as a 16 bit integer then each of the 65536 possible combination that the 16 bit value can have will map to a discrete AFR value.
    I.e.
    0 = 0
    1 = 0.0009765625
    2 = 0.001953125
    3 = 0.0029296875
    15052 = 14.69921875
    15053 = 14.7001953125
    65534 = 63.998046875
    65535 = 63.9990234375
    So you can see not only are the values discreetly quantized, but they cannot even accurately store 14.7 since there is no integer value that can exist between 15052 and 15053
    Given the limitations of the CPU in the PCM, the GM engineers/programmers traded accuracy for speed. Obviously they figured 3 decimal places was enough accuracy for AFR computations.
    Nov 2006
    Thanks Paul.
    Comparing 2 logs I have;
    one with 24 channels selected and has the "off" values for GM.AFR
    and the other has 23 channels selected and GM.AFR is right.
    LC-1 WBO2
  1. B3601 value for E10
    Last Post: August 28th, 2015, 12:09 AM
  2. B3601 and returning to CL
    By Gregs in forum Gen III V8 Specific
    Last Post: May 1st, 2010, 12:48 AM
  3. B3601 equivalent in E38
    By Chalky in forum E37, E38 & E67 PFI ECM's
    Last Post: September 8th, 2009, 12:02 AM
  4. Logworks and {B3601}
    By mr.prick in forum General (Petrol, Gas, Ethanol)
    Last Post: June 28th, 2009, 06:24 PM
  5. B3601
    By johnv in forum General (Petrol, Gas, Ethanol)
    Last Post: November 23rd, 2005, 11:24 AM
