Results 1 to 4 of 4
Thread: Clearing history codes
    Junior Member Denaliano's Avatar
    Apr 2007
    Default Clearing history codes
    Can this be done?
    I've tried several times, (shift F10) just replaced a wheel sensor but C0222 is still showing up, as blue icon/H(istory) when I scan for DTCs.
    I swore I was able to do this before?
    Got a V1 on my 2002 Sierra Denali with EFILive 7.5
    - 2002 GMC Sierra Denali Quadrasteer 6.0L AWD, 4.10s, K&N FIPK -
    Apr 2007
    damn got it, yanked the abs fuse, cleared codes, came up as lost comm w/ebcm, shut down, put the fuse back, restarted, cleared codes, ALL GONE.
    :thumbsup:
    You have to go Info->Clear DTC's for all listed modules or SHIFT-F11...
    but first you have to go Edit->Properties->Advanced and under Diagnostic Trouble Codes checkmark next to Check/Clear DTC's for all modules.
    Junior Member Dewglass's Avatar
    Nov 2010
    On this screen you can activate what modules you what to clear. Are the modules active when it is greyed or white?? (Using V1)
    FWIW, EFI should change the programming so that it turns green when activated /on.
    '02 S10 Xtreme 4.3 Syclone power; AWD, 4L60E; 411 PCM: Walbro 255; 160F thermo: Front coil overs, 4" static drop;
  1. Help Clearing codes EFI Live V1
    By speedygoss in forum Duramax LLY
    Last Post: January 31st, 2010, 01:14 PM
  2. Clearing History
    By Lextech in forum Tips and tricks
    Last Post: June 29th, 2009, 04:50 PM
  3. Clearing Allison codes?
    By duramaximizer in forum FlashScan V2
    Last Post: May 18th, 2008, 05:33 PM
