I'm I correct in assuming that the E38.SCALEDUNVE_DMA is what represents the commanded fuel for the E38 PCM? When I enable E38AFRATIO_DMA I can't get a reading.
Did I not word the question correctly? I haven't got any responses. Please could I get some input?
I have had no problems with the E38AFRATIO_DMA pid. Have you tried manually validating the pids? Might be worth you posting a log file so we can see if you are doing something wrong.
The Tremor at AIR
I have also had no problems with E38AFRATIO_DMA.
What vehicle are you trying to log ?
I don't get anything when I use that pid either on a brand new E2 R8 Wagon. I subbed in 14.7 in the sae file instead of using E38AFRATIO_DMA pid for the ben factor calc and that worked fine for most of the VVE table tuning. I rang Paul and he said he will have a look at it
Mike
"Just a tune > yeah right !!!! "
What about SAE.LAMBDA?
Does that work with E38?
LC-1 WBO2
I really hope you didn't do this for the whole VVE as it'll have messed up the table completely. An AFR of 14.7:1 is only a close approximation for cells where you are NOT in PE mode. There you would be wanting something more like 12.6:1 so the VVE will be way, way out in the upper map zones.
Someone with this issue should post both a log and a tune. I'll dredge the log file with a utility I wrote to see what the actual data is.
Simon.
Ok, now we're getting somewhere. Thanks, for the responses! What I did was validate the E38 PIDS. In order for me to get any data that was even in the ball park to what it should be while logging BEN factor for the MAF, I had to create a map using BEN Factor Bank 1 serial wideband LS1 style. Enable that same PID and enable E38scaledunve_DMA. Nothing else I tried would make the MAP work. It would just read 0's. It would work with LS1 style but not E38 style BEN Factor.
Post the log file.......
