Results 1 to 3 of 3
Thread: Gears in 2010 Camaro...
    Redline Motorsports
    Guest
    Default Gears in 2010 Camaro...
    Since the speedo calculator hasn't worked right since I can remember, what is the best approach in making the correct adjustments with a manual trans?
    HO122 is for axle ratio; is this a "dumb" parameter or is weighed into the speedo calculation?
    What tables in the code are needed changes?
    Howard
    Solution???????
    Dec 2007
    If the Camaro is similar to the G8 the speed is probably from from the ABS system. :(
  1. Non Supported Vin 2010 Camaro SS
    By RMCR in forum Gen IV V8 Specific
    Last Post: February 10th, 2010, 10:17 AM
  2. 2010 Camaro & 150 shot
    By minytrker in forum E37, E38 & E67 PFI ECM's
    Last Post: November 10th, 2009, 05:20 PM
  3. 2010 Camaro
    By jnjprfrmnc in forum E37, E38 & E67 PFI ECM's
    Last Post: October 29th, 2009, 08:06 AM
  4. 2010 camaro
    By nchristian in forum E37, E38 & E67 PFI ECM's
    Last Post: June 15th, 2009, 10:03 AM
  5. 2010 camaro problem
    By Ls1joe in forum E37, E38 & E67 PFI ECM's
    Last Post: May 11th, 2009, 10:32 AM
