Page 7 of 20 FirstFirst ... 5678917 ... LastLast
Results 61 to 70 of 199
Thread: New Tuning Tutorial: WeathermanShawn
  1. #61
    Jul 2008
    Once you guys explained it..it seems so obvious.
    Thanks for explaining and for the CALC PIDS..
  2. #62
    In the calc_pids.txt attached to post#59 you may have noticed that I multiplied {SAE.MAP.kPa} by 1000... this allows CALC.VE_Table.VEpcm to be in grams instead of milligrams...
    actually VE units map to g*K/kPa.
  3. #63
    I applied this to some of my log files, I didn't have DYNAIRTMP logged, so I changed the calc pid to use IAT instead...
    this is what it produces, VE_Table looks pretty close...
  4. #64
    Jul 2008
    Hows it looking?(CALC VE).
  5. #65
    I updated the calc_pid.txt file... see attached.
    Changes:
    - in equation for VEpcm, multiplied MAP.kPa by1000.
    - changed VEpcm units to VE units (i.e. g*K/kPa).
    - changed VEpcm range from 0-3000 to 0-3.
    - changed LTFTBEN % range from 0-2 to 0.5-1.5 for more resolution.
    - removed extra set of parenthesis from around displacement multiplication.
ID:	7353   Click image for larger version.
  6. #66
    Apr 2009
    Would changing the high for the calc_VE to something like 110 be O.K. for boosted applications? I'm trying to understand the calc_pids boundaries in general. The only hurdle I see in this is my VE table isnt in %VE but grams/cyl. I think I need to make a BEN table to multiply my stock table with OR convert my table to %, find the difference, and go from there? Either way, I work at 3AM and will hopefully log the truck when I get home.
  7. #67
    Quote Originally Posted by TunasTwins View Post
    Yes, that's the gauge/chart high tickmark display mark, it doesn't affect the calculation.
    High = highest tickmark on gauge/chart,
    Low = lowest tickmark
    Fmt = how many decimal places
    Try the VE_Table with VE units in the calc_pids.txt I posted in post #65... not g/cyl but g*K/kPa (same as B0101).
  8. #68
    Nov 2006
    The calc_ve PID still doesn't work.
    LC-1 WBO2
  9. #69
    The calc_ve PID still doesn't work. :sad:
    Huh, what happens...?
  10. #70
    Jul 2008
    Mr. Prick, is it a displacement issue? (all zero's), and it just won't validate?
    Remember, we have two VE type PIDS. The 'newer' one that utilizes DYNAIRTMP is under Tuning..
    Last edited by WeathermanShawn; March 14th, 2010 at 03:00 PM. Reason: Additional Comments..
  1. How about a transmission tuning tutorial!
    By Redline Motorsports in forum 4speed RWD/FWD Transmission Tuning (incl T42)
    Last Post: October 3rd, 2020, 04:53 AM
  2. Tuning Notes by WeathermanShawn
    Last Post: July 12th, 2013, 03:21 AM
  3. WeatherManShawn's Tutorial: can someone look/help...??
    By tatasta in forum Gen III V8 Specific
    Last Post: April 28th, 2010, 02:25 PM
  4. Idle tuning... more info on tutorial please!
    By vxleather in forum Tutorials
    Last Post: July 16th, 2008, 12:11 PM
  5. How about a transmission tuning tutorial!
    Last Post: August 5th, 2006, 04:09 AM
