Page 2 of 2 FirstFirst 12
Results 11 to 19 of 19
Thread: Ben Factor Question
    Mar 2008
    Tell me how and what you need to see. I will gladly post it
    swingtan
    Guest
    When replying, click on the "paper clip" icon above the text box.
    A new window will pop up, in it, click on "choose" to select a file.
    Navigate to the log file and highlight it and click on "open"
    Finally, click on "upload" to upload the file.
    Then add any text to the post in the text box as normal.
    Simon.
    Mar 2008
    Ok, now I know how to upload. What do you need to see? A file from the tunong software or something from the scanning software?
    swingtan
    Guest
    the log file. It ends in ".efi" and is what you would be opening to see the logged data from the car.
    Mar 2008
    I hope this worked!
    swingtan
    Guest
    In that log, you have "GM.AFR" selected. You need E38.AFRATIO_DMA.
    When connecting to the ECM via "ScanTool" do the following...
    1. Connect the V2 to the laptop and to the ODB-II port
    2. Click on the green "connect" button ( top right in tune tool ) or press <CNTRL>-F3.
    3. Choose the Correct ECM ( E38 ).
    4. Once connected, click on the icon below the "red" button or press <SHIFT>-F2. This will validate all the PIDs.
    5. Click on the "PIDs" tab and in the "system" box, select E38
    6. Select "Air/Fuel Ratio Commanded"
    If for some reason the PID is not supported, there may be an OS issue and tech support will need to check it out.
    Simon.
    Mar 2008
    That is what I do. In this log I have the PIDs selected that I have to, to make it work. I have selected the E38.AFRATIO_DMA. PID before but it gives no data.
    Mar 2005
    [QUOTE=swingtan;116817]I really hope you didn't do this for the whole VVE
    no no of course I didn't mate...only up to about 75kpa and about 4000rpm.....I still have to get the car back to finish the VVE table in mafless mode at full load you see. Got full load timing and MAF done but that may need revisiting once the VVE is finished. The car went from 240rwkw to 270rwkw with a 2WD Dyno Dynamics Dyno.
    Mixtures at full load went from 11:1 to 12.7:1. I can see Holden just adding 10kw a year just by tweaking the factory tune lol
    Thanks for your concern
    "Just a tune > yeah right !!!! "
  9. #19
    swingtan
    Guest
    Quote Originally Posted by The Alchemist View Post
    NP, just making sure it was noted in case someone reading the thread didn't realise and tried doing the whole table.
    You could easily make a filter to exclude any data where the commanded fuel was anything but 14.7 and then use a normal MAP to get the VVE correction factors.
    EVI: upload a log where you have tried logging with E38.AFRATIO_DMA
  1. Stomp Compensation and Impact Factor, whats the difference?????
    Last Post: November 12th, 2009, 07:07 AM
  2. wideband_ben factor not showing in map dropdown
    By MattysTA in forum General (Petrol, Gas, Ethanol)
    Last Post: August 26th, 2009, 09:06 AM
  3. Auto VE Ben Factor
    By shane in forum Gen IV V8 Specific
    Last Post: June 20th, 2008, 11:34 AM
  4. Logging BEN factor with March 20th Beta?
    By Goldfinger911 in forum FlashScan V2 BB Logging
    Last Post: March 23rd, 2008, 06:03 PM
  5. Math Wizzards - BEN Factor IAT correction
    By TAQuickness in forum General (Petrol, Gas, Ethanol)
    Last Post: July 29th, 2005, 02:56 PM
