12607218 - VATS patch only required (OS default is VATS Type 3)
12612381 - VATS patch only required (OS default is VATS Type 2)
12619078 - VATS patch only required (OS default is VATS Type 2)
12624402 - VATS patch only required (OS default is VATS Type 2)
12614088 - VATS patch + VATS Type 2 + Crank Relay current (added 3/23)
12617631 - VATS patch + VATS Type 2 + Crank Relay current
12628990 - VATS patch + VATS Type 2 + Crank Relay current (depends on platform OS is used on - some do not require crank relay current).
