Results 1 to 10 of 13
Thread: Erratic AFR/voltage in EFILive
    Jun 2008
    Default Erratic AFR/voltage in EFILive
    Hi all,
    I have come across an issue with EFILive and my LM1 after I switched to a new laptop.
    I am getting a very stable and consistent voltage signal from my LM1 through the cable (3.5mm jack) into my V1 interface.
    When I turn on the Flashscan I get a very erratic and unstable voltage on the screen that swings widely (+/- 1.5+ volts)
    Since I have changed computers and with my old laptop I can't recall having these issues I was wondering what is going on.
    Are there any settings that I might have missed in EFILive that control these swings?
    Currently I have all three cables (red, white,ground) connected in the orange connector that goest into the interface. Since I get a good and stable voltage from the I would suspect that the issue lies somewhere else.
    I also log AD1 and AD2 but both are swinging the same.
    I need to do some AutoVE but can't do so until I get the AFR readings right.
    Alex
    Hi Alex,
    How is your LM-1 wired to the vehicle...?
    Are you powering your laptop from the vehicle...?
    Do you also get this when you do BBL logging with you V1 (i.e. with no laptop)...?
    Post a log file.
    Jun 2008
    Hi Joecar,
    The LM1 is powered through the cigarette lighter.
    The laptop is running on its own batteries.
    The LM1 is not separately grounded.
    I get the same AFR swings with BBL.
    Here is one recent log w/ laptop and one w/ BB
    Alex
    Questions:
    - where is the LM-1 grounded...?
    - what have you got connected to pin D (signal ground) of FlashScan V1...?
    Something seems wrong with a ground connection.
    Jun 2008
    Well I thought it is grounded through the cig lighter plug or the O2 sensor in the exhaust. It was never separetely grounded, but worked before.
    Which is Pin D on the V1? Do you have a picture or description? Is it the unshielded ground cable that comes from the 3.5mm jack? If yes that is connected to the middle port of the orange connector that goes into the V1.
    Is there a specific way to ground the V1?
    Again, the measured voltage at the orange connector and the displayed AFR values on the LM1 display are very constant.
    Jun 2008
    I jsut looked at the LC1 tutorial to find out which Pin D is. It is the middle port as I suspected.
    In order to ground this correctly, what should I do?
    Right now the ground cabel comes from the LM1 jack into the Pin D. Should I just get a second wire that goes from Pin D to a common ground (cig lighter)? I would leave the ground wire from the jack cable still connected to Pin D right?
    Default Buy a V2 and get a serial cable from TAQUICKNESS!
    Quote Originally Posted by Alex99 View Post
    Hi all,
    Alex
    Alex.....
    I suffered with voltage swings and huge tuning problems using analog. Some guys say it works for them, and it might....
    But, I have to wonder...."HOW DO THEY REALLY KNOW it's working accurately or just LOOKS LIKE it's working???"
    My guess is that half of them "THINK" it's good when it's really not.
    Don't take a chance. The serial will eliminate 100 hours of frustration the very first time you use it.
    Chuck CoW
    Jun 2008
    Update:
    I grounded the V1 as I explained in my previous post and it seem to lessened the swings considerably. Please have a look at my log to confirm that the minor swings I have now are normal.
    I guess this was the culprit so I can now go forward and figure out the voltage offset to dial in the actual AFR vs. the AFR in EFIlive.
    That seems better... the EXT.AD1 voltage seems yo follow your commanded AFR...
    but: the CALC.AFR_LM11 pid seems incorrect, it ranges from 20-25 AFR...
    have you reprogrammed your LM-1 for a different AFR range...?
    Run the LM Programmer utility from Innovate and see what your LM-1 is programmed to output (i.e. what AFR's do 0V and 5V equate to...?).
  1. Erratic AFR's at the track?
    By VTC_WS6 in forum Gen III V8 Specific
    Last Post: September 27th, 2008, 04:26 AM
  2. Changed my IFR...AFR Is erratic
    By zapp168 in forum General (Petrol, Gas, Ethanol)
    Last Post: August 8th, 2007, 05:19 AM
  3. LC-1 WB voltage Q?
    By 99Silver6.0 in forum General (Petrol, Gas, Ethanol)
    Last Post: May 28th, 2006, 10:55 AM
  4. TPS voltage
    By driver456 in forum General (Petrol, Gas, Ethanol)
    Last Post: April 23rd, 2006, 03:41 AM
  5. Erratic LTFTs after VE tune
    By mtnman in forum General (Petrol, Gas, Ethanol)
    Last Post: March 23rd, 2006, 11:36 AM
