Page 4 of 7 FirstFirst ... 23456 ... LastLast
Results 31 to 40 of 61
Thread: Stock GEN IV Files
  1. #31
    Senior Member VortechC5's Avatar
    Jun 2003
    Oops, I forgot to send the files to Tordne. Sorry for the delay.
    I just sent them to him to be added to Holden Crazy.
    02 C5 Coupe - LS7, TSP 265 LS7 heads, ARH, Z06 cat-back, HREs, 3.73 gears, Wilwood brakes, DeWitts radiator
    15 C7 Z5 1 Coupe - stock for now
    12 Avalanche - tune, Corsa Touring
  2. #32
    Nov 2006
    Default 2010 Camaro LS9 supported?
    We did a LS3. EFIlive does not recognize this LS9 auto Camaro.
    Thanks.
    Alex
  3. #33
    Quote Originally Posted by CarbConn View Post
    Thanks.
    Alex
    Hi Alex, what are your V7.5/V8.1 software build numbers...?
  4. #34
    Oct 2004
    That calibration you sent via email is supported with the latest pre-release version 7.5.6 Build 107 available here (http://forum.efilive.com/showthread.php?t=13140).
    Also download the 8.1.2. Build 87 release and update firmware to 2.06.28. Also get the ZIP file in post # & of that thread and extract to the location shown in that post.
    Andrew
    EFILive Crew
  5. #35
    Yes get the zip file from post #7: http://forum.efilive.com/showpost.ph...40&postcount=7
  6. #36
    Nov 2006
    Thanks guys, it worked!
  7. #37
    Jun 2010
    can you tell me if this controller is supported. 2006 C6 Auto trans vin#********
  8. #38
    Oct 2004
    I can advise that the E38 T43 controllers used by that VIN (which I've removed) are supported by FlashScan V2 Scan and Tune.
    Andrew
    EFILive Crew
  9. #39
    Quote Originally Posted by bfabiano View Post
    That VIN has had the following OS updates:
    12600132 - not supported by EFILive (Main Operating System)
    12601696 - not supported by EFILive (New software for start of production)
    12602922 - supported by EFILive (New software to correct problem occurring at the assembly plant. Does not address any service issues.)
    12605196 - not supported by EFILive (New software to eliminate erroneous "Max speed 158 mph" DIC message.)
    12605732 - supported by EFILive (New software to ensure proper catalyst monitoring.)
    12614682 - supported by EFILive (New software contains diagnostics enhancement for DTC P0128 and DTC P0507. Also addresses battery drain.)
    If he has one of the non-supported OS, he should be able to upgrade any non-supported OS to the latest OS.
    Plus, any dealer should upgrade his ECM to 12614682 whenever it goes in for a service.
    bfabiano,
    EFILive supports the vehicle you enquired about (VIN provided by you).
    However, you may have to upgrade to a supported OS... the latest one is 12614682.
    Goto http://tis2web.service.gm.com/tis2web and enter your VIN, select PCM/VCM and click Next...
    you will see what the dealer will upgrade your OS/calibrations to (the latest one is at the top, 12614682).
  10. #40
    Apr 2008
    Quote Originally Posted by jrh View Post
    Per the GM TIS web site, that VIN should have one of the two following operating systems:
    VIN:1G1YY24U955100573
    Controller:PCM/VCM
    Powertrain/Vehicle Control Module Calibration History for: Main Operating System
    Part Number
    • 12613186
    • 12605740
    Both of those operating systems are supported by the current EFILive software.
    I am not sure why your vehicle is showing 12595751 as an operating system. Are you sure you are looking at the correct file tab because that part number is the speedometer calibration file part number for your vehicle. Are you using the latest EFILive software that supports E40?
    If you are still having these issues I would get your vehicle flashed by a dealer to the latest stock calibration files and that should give you the correct operating system (or you can do it yourself if you have the software/hardware to do so).
    If you had a stock EFILive calibration with ALL the correct files for that vehicle, you could also use EFILive to update the vehicle.
    BTW - anyone can check what the correct files are for a specific VIN GM vehicle by going to:
    Jason
    good info
    Regards,
    Odd Boy
  1. Stock LS3 tune and trans files..
    By Chris81 in forum Gen IV V8 Specific
    Last Post: April 20th, 2008, 12:57 PM
  2. EFILive Stock *.tun Files!!! In Here!!!
    By Black02SS in forum General (Petrol, Gas, Ethanol)
    Last Post: March 12th, 2008, 07:45 AM
  3. E38 stock files needed
    By Lennart in forum E37, E38 & E67 PFI ECM's
    Last Post: February 10th, 2008, 04:42 PM
  4. Stock tuning files, All years please!
    By ScarabEpic22 in forum LL8 4.2L In-Line 6 - P10 PCM
    Last Post: August 17th, 2007, 06:48 AM
