Page 5 of 9 FirstFirst ... 34567 ... LastLast
Results 41 to 50 of 86
Thread: LBZ equivalent of B0751/B0752?
  1. #41
    Jan 2008
    I just noticed that B0793's and B0794's values are swapped between the LBZ and LMM. That's kinda weird. And something else i think is weird is that on and LMM where this tables supposedly works it's tuned out from the factory with B0797??? could it be that this 0797 is the rpm disable for 0795 rather the 0797 being the enabler???
  2. #42
    did you also try rpm setting up high?
    Custom Tuning Services
  3. #43
    Jan 2008
    not yet. But the stock setting was 6000rpm so if it (b0797) was the disabler the table (b0795) would have already be activated.
    I'l play with it some more.
  4. #44
    Jan 2008
    Back from playing with good news for Josh and Michael!!!
    In a laps of divine wisdom that had been bestowed upon me from generation upon generations of performance diesel tuning i had forgot that lambda was the inverse of EQ. So in my earlier post i had stated that setting B0795 to anywhere between .9 and .3 was not doing anything, but was in fact loosening up the fueling without being able to tell. So, when i went to play again i change the max rich mixture (B0794) to 2.0 (.5 EQ) the smoke magically disappeared and when i set it back to .1 lambda (10 EQ) (way extreme btw, i know just proving a point) the smoke magically reappeared!!!
    However, the "rpm enabler" seems to have no affect on the B0793-B0795. With it set @500 or 6000 the tables still were affecting the smoke level.
    AND, with the max mixture set .2 the truck shifted way funny. It wasn't downshifting like it should have.
    I logged a few runs and it seems the way it is controlling smoke is with the mm3 reference not PW (or i guess it would be PW indirectly) So i suppose this is why it was messing with the trans shift patterns.
    Sorry to make you day dream about playing with an LBZ Michael... lol
  5. #45
    Jan 2008
    Oh, i forgot to say "hats off to Ross for bringing us an early Christmas present!" Much appreciated!!!
  6. #46
    Sounds good!
    Quote Originally Posted by bballer182 View Post
    In logging past, I had noticed strange PW reductions that did not correlate to mm3, what amounted to unexplained, inconsistent anomolies.
    Does it appear that mm3 is being limited, AND that PW is tracking mm3?
  7. #47
    Jan 2008
    Sounds good!
    yes, it appears to me that the PW is following what the commanded reduction of the mm3 reference is. I don't think that this is a TQ reduction, but rather just a mm3 reduction.
    Which, brings me naturally to more questions; how does the ECM calculate the mass of air in the cylinder? Is it boost based or is it based on what the MAF has to say? And is there a pid which displays for us the lambda reference it is using? And is there a pid which will tell us how much air the ECM thinks is in each cylinder?
  8. #48
    Did a few logs, with different combinations.
    I loaded all 2.0's and still have eq going over 1.1 (with significant smoke) on spool up. It is better than the 1.3-1.4 eq I was getting. I loaded all 0.2's and got 1.9 eq, so there appears to be a help for sure.
    I am confused a bit. If higher values limit smoke (lean), then the desriptions in the limit tables are confusing. The lean limit would be the higher number, yes? Here are the stock numbers.
    {B0793} Main Injection Lean Mixture Limit 0.92 lambda
    {B0794} Main Injection Rich Mixture Limit 1.40 lambda
  9. #49
    Jan 2008
    yeah see! thats what im talking about?!?!? these tables don't make much sense...
  10. #50
    Feb 2007
    This is awesome. I've been so busy I keep forgetting to check this when I'm at home. I'm going to download this first thing when I get back to the house! Thanks everyone!
  1. B3601 equivalent in E38
    By Chalky in forum E37, E38 & E67 PFI ECM's
    Last Post: September 8th, 2009, 12:02 AM
  2. B0751 MAF limited fuel quantity
    By killerbee in forum Duramax LLY
    Last Post: September 18th, 2006, 10:47 AM
