Page 3 of 3 FirstFirst 123
Results 21 to 27 of 27
Thread: cant get stock tune off truck
  1. #21
    Junior Member browneflatwork's Avatar
    Nov 2009
    i take that back truck starts to read on alt keys but stops after 24kn frezes up
    EFI....SC IV,fass 150,sleeves, MBRP 4in TB,afe intake, shimmed rail, blocked egr,auto meter c2 gauges, home built trac bars,
  2. #22
    Can you post the text or a screenshot...?
  3. #23
    Nov 2009
    it doesnt say anythign...just completly stops reading after 24-28k even if i let it sit for 10min wont finish reading
  4. #24
    Oct 2004
    Can you please check for debug files (BLX) as described here (http://www.efilive.com/index.php?opt...111&Itemid=121) and email them to me at support@efilive.com?
    Andrew
    EFILive Crew
  5. #25
    Nov 2009
    bug file sent from browneflatwork
  6. #26
    Oct 2004
    First up it looks like your software and firmware versions are not in line (you're running 7.5.6 software with the older 2.06.12 firmware).
    Can you please update everything from this thread (http://www.efilive.com/index.php?opt...=48&Itemid=133) and try again. After all these updates you should have versions 7.5.6 Build 109, 8.1.2 Build 89 and FlashScan V2 firmware 2.06.30.
    Andrew
    EFILive Crew
  7. #27
    Nov 2009
    updated everything will try to read truck again shortly thanks
  1. Help Please**** LLY With A LBZ Computer Stock Truck
    By Duramax 6.6L in forum Diesel
    Last Post: June 2nd, 2010, 12:48 PM
  2. Stock truck idle problems after flash..?
    Last Post: August 28th, 2009, 09:07 AM
  3. Tune for 07 6.0L truck?
    By 07.5duramax in forum Gen III V8 Specific
    Last Post: February 25th, 2009, 05:54 PM
  4. Truck Tune
    By cmitchell17 in forum Gen III V8 Specific
    Last Post: May 13th, 2007, 02:25 PM
  5. Help with tuning stock truck
    Last Post: February 23rd, 2007, 10:27 AM
