View Poll Results: Which Do You use? ( you can select more than one )
Voters
157. You may not vote on this poll
  • Accel
    1 0.64%
  • AEM
    24 15.29%
  • Bosch
    3 1.91%
  • Inovate
    80 50.96%
  • FJO
    7 4.46%
  • NGK
    13 8.28%
  • PLX
    21 13.38%
  • TechEdge
    17 10.83%
  • Zeitronix
    1 0.64%
  • Other
    14 8.92%
Multiple Choice Poll.
Page 1 of 10 123 ... LastLast
Results 1 to 10 of 91
Thread: Wideband Controller Poll
    swingtan
    Guest
    Default Wideband Controller Poll
    There are a couple of threads on who uses what, but none that make it easy to see just how many use what. So vote for the WB controller you use and help those that are wanting to get one decided....
    Simon.
    Junior Member SirNemesis's Avatar
    Dec 2007
    TechEdge 2J1 for me, with the LA1 display.
    Innovate LC1 with serial connection to V2, soon to add Innovate DB blue guage for real time monitoring.
    LC-1
    Used with both V1 and V2 using analog connection.
    Bench tested with V2 using serial connection... to be installed soon with heads/cam/headers/catback (but I have to do suspension first).
    Oct 2006
    Innovate LM-1 with serial connection for me.
    The Tremor at AIR
    Member JAY4SPEED's Avatar
    Mar 2007
    I have a Innovate LM1 (serial) for tuning customer's cars and I have the PLX (with serial conversion) permanently mounted in my truck.
    Oct 2004
    I have dual LC-1's sitting here to be installed. If I could afford to I would go dual FJO Racing though with the NTK sensors. Just a little pricey for me unfortunately :(
    Andrew
    EFILive Crew
    I have setup several LM1's with the serial connection, its just too easy.
    Al
    Aug 2008
    V2 w/ Innovative Dual Channel LM-2 with TAQ serial connection, Bosch sensor's go bad quick, wish I could use NTK sensor's with LM-2
    FLASHSCAN V2 & AUTOCAL
    Nov 2006
    Where did you get the idea for a WBO2 poll?
    LC-1 and V2 with serial connection FTW.
    LC-1 WBO2
  1. Custom OS Poll
    By GMPX in forum Gen III V8 Specific
    Last Post: September 6th, 2007, 05:13 PM
  2. "Best" Wideband Controller for Portability?
    By agreif in forum General (Petrol, Gas, Ethanol)
    Last Post: October 25th, 2006, 02:50 AM
  3. test poll
    By TAQuickness in forum Tutorials
    Last Post: July 21st, 2006, 07:14 AM
  4. SD Poll
    By johnsZ06 in forum General (Petrol, Gas, Ethanol)
    Last Post: October 25th, 2005, 09:48 AM
Tags for this Thread
