Results 1 to 3 of 3
Thread: crank angle sensor error
    Feb 2008
    Default crank angle sensor error
    how do i get the case to work on the scanner with a cos 3 for my lq9 402. i hit the case button and nothing happens. if i go to use anything it all works engine trans ect. engines at opp temp in park at idle
    When you press the CASE button, you then have to increase engine RPM to above 4000 (you have a 10 second window in which to do this), at the right RPM engine will stumble sharply for a moment, you have to immediately release throttle and let engine spin down to idle... then turn off key and wait at least 15 seconds.
    Dec 2007
    Is this engine is a production car/truck or in a retrofit?
  1. Crank sensor relearn 97 chevy truck
    By Gregs in forum General
    Last Post: March 29th, 2010, 02:21 AM
  2. E38 Crank Position Sensor Relearn
    By hapnermw in forum Gen IV V8 Specific
    Last Post: May 2nd, 2009, 04:58 PM
  3. learn crank angle sensor error
    By Dottry in forum General
    Last Post: October 10th, 2008, 05:16 AM
  4. A new angle (crank that is)
    By Spindoctor in forum Gen IV V8 Specific
    Last Post: March 13th, 2008, 08:46 AM
  5. crank posion sensor HELP
    By woody69 in forum General (Petrol, Gas, Ethanol)
    Last Post: December 28th, 2006, 09:24 AM
